11-19-2006, 12:38 AM | #1 |
pics of air ride up and down
can i get some pics of air ride trucks up and down? i'm planing on doing air bags but want to see how much they will travel from the up position and aired down.
thanks chris |
11-19-2006, 12:56 AM | #2 |
Re: pics of air ride up and down
It depends on the bags you use. When my truck is all done, I will have about 5 inches of adjustment (maybe more). I am using 7" front and 6" rear Slam Specialties.
I'm also about 3" higher than some when I'm dumped because of the bags I used and didn't trim my front cups. |
11-19-2006, 12:58 AM | #3 |
Questionable
This is not me being condescending, it's me trying to get you answers fast:
If you go up to the main part of this 67-72 year forum, then look in the upper right-hand side, you'll see a search button. click on that, then type either 'bags', 'airbags', 'bagged' or 'aired' and search on that term. Then click on any thread you see in the results that has a paperclip symbol next to it. This will show you any threads where people are talking about bags, bagged trucks, or trucks aired out. You might hafta dig a bit, but you will find what you're looking for. The search will not work for 3-letter terms, just so you are aware. Stick to 4-letter words or more.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link) I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM. |
11-19-2006, 01:53 AM | #4 |
it really depends on your set up and products. It can vary quite a bit.
11-19-2006, 02:40 AM | #5 |
i did search. couldnt find any pics of rucks aired up just down
11-19-2006, 02:41 AM | #6 |
I also agree that it varies alot. Different bags have different ride heights and different lift heights. Also it depends on how you mount them. I am in the process of mounting my rear air bags in a canti-lever setup. I plan on getting 9-10" of lift for the rear. Anyways good luck!!
Josh
(Project truck) 1970 C10 under complete transformation My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871 Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold |
11-19-2006, 12:28 PM | #7 |
This is Slammed67's truck. He is using Firestone bags in the stock locations with a c-notch and dropped spindles.
*EDIT* - I "believe" that the up pics are ride height, so if needed could possibly go a little higher.
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build Last edited by smbrouss70; 11-19-2006 at 12:29 PM. |
11-19-2006, 04:04 PM | #8 |
Straight jacket required
Any other mods to this truck to get it this low?
1968 C10 Short Stepper 350/350 A/C P/S P/B Front disc 3/5 static/ 12bolt rear 3:73 1979 Pontiac Trans Am 10th Anniversary/455/4spd 2011 H-D Street Glide - CAMMED n lowered Dad always said,"Son, if you can't be good...be good at it." |
11-19-2006, 05:39 PM | #9 |
what size wheel/tire and backspacing?
11-19-2006, 06:42 PM | #10 |
Questionable
http://67-72chevytrucks.com/vboard/s...2&postcount=77 Member 'OLDROCK&ROLLER' has pics of his floating around here, I just don't want to spend the time searching for it. Several people have posted pics - I would also check the suspension forum, not just this 67-72 forum.
11-20-2006, 02:17 AM | #11 |
Sorry guys, not my truck. It belongs to a member, Slammed67
Steven "If dogs don't go to heaven, when I die I want to go wherever they went." -- Will Rogers R.I.P. Oscar R.I.P. Ratchet 1967 Pontiac GTO - Dad was the Original Owner 1970 Chevy 2wd SWB "Oscar's Truck" 1970 Chevy 2wd Blazer "Ratchet's Blazer" 2013 Chevy 2500HD Crew Cab Duramax/Allison Z71 LTZ "Brown Sugar" 2017 Chevy Suburban "BDB" 2020 Chevy Blazer Premier "Foxy" Member of Louisiana Classic Truck Club (LCTC) Shop Build |
11-20-2006, 02:41 AM | #12 |
Heres mine. I did a c notch in the frame and have 2" drop spindles. My kit is from air ride tech. I built snubbers so I could drive it if I lost a bag. So it could go a little lower but I did not do anything to the bed and I still have the inner fenders. The up picture is not the best. I have 20's on this truck and at it's lowest point I can still drive and turn it.
