Old 11-19-2006, 12:45 AM   #1
Slammed70
Slammed70's Avatar
Head gaskets.....?
Im on my lunch break at work, my town gets stupid and busy around lunch time....so I had to be a little mean to my truck.
I pulled out in front of a semi and floored my old truck as not to get rearended. Well when I did that the truck sputtered a little bit then cleared up and laid some rubber.
But the weird thing is now I can smell antifreeze all the time.....
Theres no visible leaks, it still runs fairly decent, the radiators still full (I dont have an overflow tank thing)
But now my heater works better then ever, I dont get it.
Mitch.
Slammed70 is offline   Reply With Quote
Old 11-19-2006, 12:49 AM   #2
mtb_will_03
mtb_will_03's Avatar
Re: Head gaskets.....?
do you smell it when ur heaters on ?
or just with the truck ideling or what ?
mtb_will_03 is offline   Reply With Quote
Old 11-19-2006, 01:12 AM   #3
Slammed70
Slammed70's Avatar
I smell it all the time...well kind of, I get a whiff of it almost all the time
Old 11-19-2006, 01:14 AM   #4
mtb_will_03
weired cuz you say the rad stays full
Old 11-19-2006, 01:44 AM   #5
GMCMAX
Active Member
GMCMAX's Avatar
Smell it inside the cab or outside? I've had a seam leak on a newer truck, it wouldn't leak fluid, but I could smell coolant. I pressurized the system and spritzed soapy water on the rad and it was bubbling on a seam. It was a vapor leak under pressure.
Just don't make like a guy at work, he saw a puddle in the cab floor, thought his heater core leaked, tasted it, and found out it was kitty cat leakage.
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 11-19-2006, 01:49 AM   #6
bodydropped69
bodydropped69's Avatar
check your dipstick to see if you see coolant in there.
bodydropped69 is offline   Reply With Quote
Old 11-19-2006, 01:53 AM   #7
krue
Designated A-hole!
krue's Avatar
Check your radiator for bubbles with the engine running, water in the exhaust, water in the oil, oil in the water.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 11-20-2006, 03:36 AM   #8
Americanrider
I'll bet your heater core has sprung a leak, check around the heater box under the hood and under the dash.
Americanrider is offline   Reply With Quote
