11-19-2006, 11:50 AM | #1 |
Oops! What did I mess up now?
I finally removed the bed & was cleaning up the frame & such with a wire wheel on a 4.5" grinder. When on the rear end I came across this.
There are apparently about 6 of these little spots that appear to be welded. Unfortunately, I found 2 of them after the wire wheel ate through them. What are they for? How should I close them up? Is it just to keep the elements out & I should use RTV? Or do I need to MIG them back shut? If MIG, do I need to drain the pumpkin first? Thanks, John O>.
85' CUCV M1009!!! The newest addition! 6.2diesel, Th400, NP208, & only 36k miles! 70' C-10 LWB Fleetside - Looking good these days! 05' Dodge Neon 88' Winner Escape Sport 1750 - 4.3v6 94' Seadoo SP 84' Honda TRX200, bare nekkid. Just a frame & tires. Always looking for another project or any good deal! |
11-19-2006, 12:06 PM | #2 |
Re: Oops! What did I mess up now?
jb weld should do the trick
11-19-2006, 12:10 PM | #3 |
i think they maybe rivet heads to keep the tubes in place during assembly// i'd take a piece of wire and see how far you can push it into the hole if it comes out wet ,it will leak if it doesnt go in far less than 1/4inch nothing to worry about
11-19-2006, 12:40 PM | #4 |
Rottenwood Garage Member
11-19-2006, 01:10 PM | #5 |
Designated A-hole!
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
11-19-2006, 01:34 PM | #6 |
they're just gas pockets from when the tubes were welded in. i welded mine in with no issues but JBweld would work just as well.
11-19-2006, 07:55 PM | #7 |
Location: vacaville ca, because it as far from indy as i can be
its just welding slag or as said before a gas bubble when the tube was welded in, seeing as that the tube goes in about 2-3" past that with a +.005-.010" fit i woulndt sweat it leaking , that is unless you think you are bo duke and jump the local river once a day.
11-19-2006, 08:51 PM | #8 |
Thanks for the good info. I think JB Weld will do the trick.
John O>.
