11-19-2006, 12:31 PM | #1 |
New Member
oil on my intake
Hey guys I'm a newbee, recently bougth a 69 swb has a 350 with eldebrock intake. I'm noticing oil pooling around my two inboard bolts both sides on the intake. I guessing it may comming up through the bolts?? any thoughts? if so think new gaskets and retorque??
Thanks NeaL |
11-19-2006, 12:45 PM | #2 |
Re: oil on my intake
WELCOME.. NAW I DON'T THINK YOU'LL NEED A NEW INTAKE GASKET IF IT'S NOT LEAKING ANYWHERE ELSE. REMOVE THE BOLTS, CLEAN THEM & PUT THREAD SEALER ON THEM JUST LIKE YOU WOULD A HEAD BOLT. DO ONE BOLT AT A TIME & YOU SHOULDN'T NEED A NEW GASKET. JOHN
junkyardjohn 69 1 TON TOW TRUCK // 84 4WD CUCV BLAZER// 85 1 TON 4WD STAKE TRUCK// 86 M1031 5/4 TON 4WD CUCV// ALOT OF OLD TRUCKS FOR ONE OLD MAN TO DRIVE. THERES ROOM FOR ALL OF GODS CREATURES RIGHT NEXT TO MY MASHED POTATOES// LIFE MEMBER OF P.E.T.A (PEOPLE EATING TASTY ANIMALS) DON'T RENT U-HAUL ALWAYS TELL THE TRUTH IT WILL AMAZE PART OF THE PEOPLE & ASTONISH THE REST |
11-19-2006, 01:08 PM | #3 |
Designated A-hole!
Welcome to the board from South Mississippi! Try the thread sealer first, if that doesn't work, then you can replace the gasket.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
11-19-2006, 01:36 PM | #4 |
clean the bolts real good and better yet bead blast to allow thread sealer to have a real good grip allow thread sealer to setup for 15minutes or so before reinstalling
11-19-2006, 01:41 PM | #5 |
I had the same problem. Mine was leaking from the valve covers (cheap thin sheet metal chrome). I installed a set of nice heavy Edelbrock covers after cleaning everything up and it hasn't leaked since. I was told I might have over-tightend the cover bolts on the cheap covers.
11-19-2006, 02:07 PM | #6 |
New Member
Thanks for the input i will give that a try!
NeaL |
