Old 11-19-2006, 02:57 PM   #1
ghetto_superman
ghetto_superman's Avatar
firewall differences from linkage to cable.
so im smoothing the firewall on my 68 with a throttle linkage.. im not a big fan of the linkages and would like to change it to a cable.. i realize theres a thread on it, but thats just retrofitting and fabbing a cable to fit more or less... i was wondering if it would even be feasible to cut a chunk of a cable firewall out and weld it in to mine.. or if mine already has the necesarry mounting points.. i just have to open them up... it would also help me if anyone posted pics of their smooth looking cable setup.
also i know that 71-72 comes standard with cable, but was it availavle on 69-70? (ill be getting a parts truck soon and i think its a 69-70)
thanks for all the help!
-Mike
-1947 3100 -1968 C10 -1970 K20
ghetto_superman is offline   Reply With Quote
Old 11-19-2006, 03:33 PM   #2
qksilver
Re: firewall differences from linkage to cable.
look at loctar , i think that is how it is spelled, pedals and cables. They offer some really clean looking designs
qksilver is offline   Reply With Quote
Old 11-19-2006, 03:43 PM   #3
krue
Designated A-hole!
krue's Avatar
Cable was not offered n 69
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 11-19-2006, 07:14 PM   #4
PICKMUP
"Trucks with Class"
PICKMUP's Avatar
You can mount the 71-2 pedal assy to the earlier firewall. Drill mounting holes and cable hole...then fill the holes left over from linkage setup. The Lokar cable works even better than the OEM, with the 71-2 pedal.
PICKMUP is offline   Reply With Quote
Old 11-19-2006, 08:55 PM   #5
jamis
F.A.S.T. president
jamis's Avatar
Here are some pics how I did it. You can see the relationship from the original pedal location for the rod style. Once mounted the new pedal assembly you have to tweak the upper part of the pedal assembly so it doesn’t hit the hump on the side and you pretty much have to locate the cable eye in the flattest area possible, then drill from the inside out a small hole using the cable hole on the pedal as a guide Then I used a die grinder to make the square hole.
F.A.S.T. President and Founder
Fabricators for the Advancement of Sawsall Technology
"A fear of the Sawsall is a sign of retarded sexual and emotional maturity." ~Sigmund Freud, "General Introduction to Psychoanalysis"
jamis is offline   Reply With Quote
Old 11-20-2006, 02:26 AM   #6
ghetto_superman
thanks guys! jamis are you the person who wrote the thread on this conversion? i dont remember much.. but it looks like the thread i remember seeing.. maybe in just
Old 11-20-2006, 02:26 AM   #7
ghetto_superman
btw any other pics are still appreciated!
Old 11-20-2006, 08:58 AM   #8
jamis
F.A.S.T. president
jamis's Avatar
That wasn't me superman, I remember the thread your talking about, mine is very similar just the location is a little different. I tried to search for the thread for you, but I could not find it. If there is anything else I can help with let me know. All the other pictures I have show just about the same thing. If you need a picture of the cable installed and the carb bracket let me know.
Old 11-20-2006, 09:11 AM   #9
neonlarry
neonlarry's Avatar
You are probably thinking of Putter's post:
http://67-72chevytrucks.com/vboard/s....php?p=1383300
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 11-28-2006, 03:03 AM   #10
ghetto_superman
ok sweet thanks guys!
