Old 11-19-2006, 05:20 PM   #1
Jwill41
Jwill41's Avatar
low beams not working
My low beam headlights stopped working. All four (GMC) work on high beam but nothing on low. Could this be the dimmer switch? It seems like I had this problem once before and it was the dimmer switch.
http://www.picturetrail.com/jwill41
67 1/2 ton GMC short step side
68 1/2 ton Chevy long fleet side
72 1/2 ton Chevy Suburban
99 1/2 ton Chevy Suburban
founder (and only member) of the primer/clearcoat club
Jwill41 is offline   Reply With Quote
Old 11-19-2006, 05:32 PM   #2
krue
Designated A-hole!
krue's Avatar
Re: low beams not working
Would be the first thing I would suspect.
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 11-19-2006, 05:48 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
yep... most likely. Try kicking it or turning it from high to low a few times.
Old 11-19-2006, 06:02 PM   #4
Boise69
The Hammer Man
Boise69's Avatar
Try moving the wires around near where they connect to the switch, mine does this too but i'm waiting for my new harness before i replace it. so once in awhile i have to wiggle em
Boise69 is offline   Reply With Quote
Old 11-19-2006, 06:13 PM   #5
Jwill41
Jwill41's Avatar
replaced the dimmer switch, still not working
Old 11-19-2006, 06:37 PM   #6
Jwill41
Jwill41's Avatar
now i have also replaced the switch in the dash, still not working
Old 11-19-2006, 06:38 PM   #7
89 crew
The first thing I would do is test the lights. make sure they work. just jump a hot with to it. since you have already replaced the dimmer switch, the problem has to be in the wires, unless the switch is bad. might try probing with a test light to make sure. after that it would have to be either a broken wire or corrision on the terminals.
89 crew is offline   Reply With Quote
Old 11-19-2006, 06:52 PM   #8
Jwill41
Jwill41's Avatar
it puzzles me that they all four work on high beam. it seems like they wouldn't work at all if it were a bad connection.
Old 11-19-2006, 08:02 PM   #9
Jwill41
Jwill41's Avatar
I just now figured it out.I put my foot in to push the dimmer switch and missed it. While pressing on the carpet they started working. I replaced the plug a few years ago and there is a bad connection at the splice. Man, that was buggin me.
Old 11-19-2006, 08:23 PM   #10
Aren't the lights dual element that are for low/high beam. Maybe the low beam is just zapped on both the outer bulbs.
Never mind...I didn't refresh the page and see you are Okie dokie now.
Old 11-19-2006, 10:32 PM   #11
al's71gmc
4 eyed fever
al's71gmc's Avatar
Had the same problem on my son's truck. I didn't get it figured out by the time he took the truck off to college, so I ended up disconnecting the high beams. All he has is lows, but at least the cops won't ticket him for blinding people. I replaced the dimmer switch, no go. Searched for hours trying to figure how all 4 can work, but not the lows by themselves.
1971 GMC 2500 4x4
1972 GMC Sierra Grande 1/2 t 4x4-#1 son's truck. Recently completed resto.
4 YO daughter," Daddy, I like your truck better than Mom's." (2000 F350-ranch truck) Smart kid!!
al's71gmc is offline   Reply With Quote
Old 11-20-2006, 10:37 PM   #12
89 crew
The way the headlights work is one wire from the headlight switch. It goes to the dimmer switch and 2 wires go out from there. (one high beam one low. Same output voltage) the head lights will have either 2 or 3 connectors on each one will be ground the others hot. If 3 contacts on the lamp 2 hot 1 low beam, 1 high, 1 ground. If 2 contacts one high beam, one ground. Long as you keep it simple like that it is easy to diagnose. if any lights work you have power to the dimmer switch. If you then probe the dimmer and have power going out it has to be wires or bad lights.
