Old 11-19-2006, 05:37 PM   #1
abadsvt
abadsvt's Avatar
Front and rear disc brakes conversion questions
Hello All! Here is my cituation. I bought a set of wheels with 5x4 3/4 bolt pattern. I have decided to upgrade my brakes and would like a 12" or larger front disc brakes and a similiar size rear disc brakes. I already bought a set of drop spindels for my truck so i am not sure if that matters. I don't know brakes and have been trying to do my homework but all of the threads on brake conversions were for 5x5 bolt pattern. I understand that i can have them redrilled but wasn't sure if i can skip that step and just buy a set already made for 5x4 3/4 bolt pattern that fit my spindel. I don't want to spend more than 500-600 if possible. Also i don't mind fabing up a bracket for the caliper. I would like to have some corvettle calipers if possible. I like the writing on the side saying Corvette. I know it is stupid but think it would look sweet. Thanks Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 11-19-2006, 06:35 PM   #2
abadsvt
abadsvt's Avatar
Re: Front and rear disc brakes conversion questions
I was looking at ebay. Does anyone know if a corvette caliper will work on any other rotor besides just a corvette rotor? I was looking at a 68 camaro rotors and was thinking i might be able to put the corvette calipers on it? It will have the correct bolt pattern i need. Sorry for my ignorance on brakes. thanks Josh
(Project truck)
Old 11-19-2006, 07:04 PM   #3
68 short step
cpp sells a 5x4 3/4 12" direct replace ment rotor, that'll take care of the front.... the rear just get a pair of replacement axles for that pattern ( any manufacture will make them to your spec)
68 short step is offline   Reply With Quote
Old 11-19-2006, 07:32 PM   #4
abadsvt
abadsvt's Avatar
Is that rotor for a camaro or something else with the bolt pattern? Will that work with my spindel?
Thanks Josh
(Project truck)
Old 11-19-2006, 08:54 PM   #5
abadsvt
abadsvt's Avatar
I found the kit you are talking about. Thanks. I was wondering if calipers are interchangable? I would like to have more than single piston caliper. Maybe a dual piston or 4 piston caliper. Thanks Josh
(Project truck)
