Old 11-19-2006, 07:58 PM   #1
slepysal
slepysal's Avatar
hood springs
So I got my new hood springs, and I' ve looked in my shop manual, but I cant find how to replace the spring. Any tips?
slepysal is offline   Reply With Quote
Old 11-19-2006, 09:23 PM   #2
Chevy Fleetside
Chevy Fleetside's Avatar
Re: hood springs
first prop the hood up with a stick or something.. Then you can loosen the front bolt on the hindge and remove the rear bolt and the hinge should move close enough to take the spring off and put one back on.. Mark the location of the hinge first so you can put it back where it was so the hood will stay lined up...
Chevy Fleetside is offline   Reply With Quote
Old 11-19-2006, 09:43 PM   #3
slepysal
slepysal's Avatar
Re: hood springs
thanks !!!! I knew some one wolud come thru
Old 11-19-2006, 09:44 PM   #4
raphyel
Re: hood springs
The way I installed/removed mine is to use a piece of nylon rope to stretch them. Hook one end and use the rope to pull the other on. Make sure you dont use something that will break. Dont know how much damage it will do, but I dont think it would be pretty.
raphyel is offline   Reply With Quote
Old 11-19-2006, 09:46 PM   #5
trkklr77
trkklr77's Avatar
Location: vacaville ca, because it as far from indy as i can be
Re: hood springs
x2
trkklr77 is offline   Reply With Quote
Old 11-19-2006, 09:46 PM   #6
49studebaker
49studebaker's Avatar
Re: hood springs
My assembly manual actually showed a picture/part number for the spring remover. I looked like a hay hook. Basically shaped like a "J" with a handle on the end.
04 4x4 GMC Ext. Cab lifted
71 2wd GMC / Ramjet 350 ready for sheet metal
49 Studebaker pickup
49studebaker is offline   Reply With Quote
Old 11-20-2006, 10:14 AM   #7
ChiefRocka
Hollister, CA.
ChiefRocka's Avatar
Re: hood springs
AAaaaah, just pry that SOB off with a screwdriver...you'll be fine !!!
JK !!!
John
Pictures....Slepy...Pictures !!!
John
What the Heck is that ??
CURRENT BUILDS:
62 BurbMaster
Other Builds:
My '63 C-10,LWB,CC,BBW
'06 HD StrAight Axle Swap
Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build
AMERICAN CUSTOMS & CLASSICS (831) 630-1965
www.ACCHOLLISTER.com
ACC on FACEBOOK
"Rest in Peace, Mom & Dad ... I will see you again someday!"
ChiefRocka is offline   Reply With Quote
Old 11-20-2006, 10:21 AM   #8
Chevy Fleetside
Re: hood springs
OH look I am quoting myself... I don't think this will work with the hood on. You might have to do it the hard way with some good rope and a handle. Either way be carful is all...
Old 11-20-2006, 11:37 AM   #9
C10-Driver
Chevy Truck Addict
C10-Driver's Avatar
Re: hood springs
Similar to the rope trick a couple of other guys have posted, wrap a rag or small towal onto the end of the spring and wrap it around your hand. Stand on one end of the hinge and pull.
Using a rag or something soft is a good way to replace the spring as it will not damage any paint or other finish you have on your hinges and springs.
1970 Chev C/10 SWB, 355 SBC, 700R4, 3.73 Posi, Air Ride (Click to view Build Thread) (SOLD)
1978 Chevy C/10 SWB
1970 Pontiac Lemans
C10-Driver is offline   Reply With Quote
Old 11-22-2006, 12:36 AM   #10
slepysal
slepysal's Avatar
Re: hood springs
rope tricked worked great !!!, The springs came of easy. But..... the new springs didnt go on . I needed some one to " convince" them in to the slot. Oh well there is always tomorow.
Old 11-22-2006, 01:06 AM   #11
trkklr77
trkklr77's Avatar
Re: hood springs
yeah the side that i could use my right hand on went like butter, the one i had to use my left hand was a little harder.
