![]() Join Date: Nov 2006
turbo 400 install questions
hey guys i got a 1971 c10 with a sbc and 350 turbo tranny. i want to install a new sbc with a 400 turbo. is the cross member the same ? what about the shift linkage ? i,d say the drive shaft has the be modified too right ?
any help would be appreciated before i dissasemble the truck. bob in tn. Last edited by BCOWANWHEELS; 11-19-2006 at 09:16 PM. |
Re: turbo 400 install questions
The crossmember will be the same and so will the shift linkage. The driveshaft is different, its shorter if i remember right.
its all about the +6 inches
You'll have to move the crossmember back, there should be holes if the engine is located properly...you may have to rework your exhaust too if it is a custom job.
i,ll check for those hole in the frame.
thanks for the help guys. bob |
E-brakes might not be important to you but the TH 400 cross member has an E-brake cable bracket attached to it for routing the cable. The attached mockup pic shows the bracket.
Jim |
not worth it, if ne thing, do the 700r conversion.
