11-19-2006, 11:42 PM | #1 |
Carrier bearing?
My carrier bearing on the driveshaft is blownout and needs replacing.
Does the carrier bearing need to be pressed on or does it just slide into place. Whats the process for removal. I tried to remove big bolt through center of driveshaft end but that baby ain't moving and I hate to break the bolt off in the driveshaft. Am I better off to take it to a machine shop? Any tips
11-20-2006, 12:17 AM | #2 |
Re: Carrier bearing?
If you have time, bring it up here. I'll fix it for ya, gratis. Not too bad a job after doing a few.
Disasemble the u-joint from the yoke with the bolt. Then you can get an impact wrench on the bolt. Use some penetrating oil and the yolk should tap off of the shaft. Then remove the bearing, it is a light press fit on the shaft. Serous, bring it up I will do that for ya. ps did you get my pm about the cab & clip ?
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 Last edited by Green Machine; 11-20-2006 at 12:26 AM. |
11-20-2006, 12:46 AM | #3 |
good luck with the replacement i been though 3 in the last year since i replaced the orginal one make sure you get a good bearing
David fuller Ase Certified Mechanic Click here to help support our board!! 1971 Chevy c-10 under going a 4.8l LSx swap Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305 2007 Honda Accord my daily 145kmiles 2002 Honda Accord 4 door With 330k(sisters car) 2005 toyota Avalon 228k( brothers car) 2002 Sububran 5.3 245k 2000 Tahoe 5.3l 378 General manager for Marco's Carwash & lube |
