Old 11-20-2006, 12:40 AM   #1
abadsvt
abadsvt's Avatar
Brake Calipers. Can they be interchangable?
I don't know alot about brakes but was curious if calipers are interchangable? I would imagine that you would need to make sure the rotors are the same thickness and possibly same diameter. I know the bracket would have to be made to hold the caliper. For example. Could you use a corvette 4 piston caliper on our rotors? Thanks Josh
(Project truck)
1970 C10 under complete transformation
My current build thread http://67-72chevytrucks.com/vboard/s...d.php?t=212871
Other project: C5 corvette swap into 70 c10 http://67-72chevytrucks.com/vboard/s...=1#post2413517 On Hold
abadsvt is offline   Reply With Quote
Old 11-20-2006, 12:09 PM   #2
abadsvt
abadsvt's Avatar
Re: Brake Calipers. Can they be interchangable?
ttt
(Project truck)
Old 11-20-2006, 01:51 PM   #3
abadsvt
abadsvt's Avatar
I just found out that calipers are interchangable as longs as you use the correct rotors specs that match the calipers. For example if your calipers are made for a 12" rotor and 1 1/4 thick rotor you must use that matching rotor specs. You have to fab up your own mounting bracket. I thought that i would share that info incase someone else was curious.
Josh
(Project truck)
