Old 11-20-2006, 01:32 AM   #1
LILREDGMC
350 Turbo Conversion
How difficult is it to convert a 4wd 350 for passenger use. I expect the case and shaft need changed, along with a seal and bushing. Anyone lend some advice to a novice on this changeover?
LILREDGMC
LILREDGMC is offline   Reply With Quote
Old 11-20-2006, 03:09 AM   #2
Bad71chev406sbc
Bad71chev406sbc's Avatar
Re: 350 Turbo Conversion
LILREDGMC
Depends of what TH350 you have to work with. Most of the cases I've seen, have a 4bolt flange for mounting to the transfercase adapter to bolt to. If it's like that, You're good to go. You'll have to have the tailshaft/output taken out for a 2wd unit. And then a tailend casing piece can go one. I got quotes to do the same thing.....anywhere from $150-200 to do this. I just ended up Trading my 4x4 unit for a 2wd unit. Looks like this when done....
4x4:
2wd:
'71 SNB, 406sbc, TH350 w/ Transpak & Starshifter, 12bolt w/ 3.73s, 2" Early Classic front coils, 2.5" Flowmaster Super 40's
Bad71chev406sbc is offline   Reply With Quote
