Old 11-20-2006, 08:56 AM   #1
prostreet1967
prostreet1967's Avatar
crank pulley clearance problems
carnk pulley won't go on its hitting the front crossmember bbc using front mounting holes anyone run in to this problem if so whats the fix underdrive pulleys and where can u get some for lwp setup?
prostreet1967 is offline   Reply With Quote
Old 11-20-2006, 08:59 AM   #2
prostreet1967
Re: crank pulley clearance problems
are the frames different for 67 compared to 68-72 since 67 wasn't avaliable with a big block?
Old 11-20-2006, 09:26 AM   #3
prostreet1967
its hitting here
Old 11-20-2006, 11:00 AM   #4
1970 CST Short Wide
Senior Moment
1970 CST Short Wide's Avatar
What mounts do you have? Are they for sure BB? I think SB sets the engine down further. Someone correct me if I'm wrong
1970 CST LS 1 6 speed Ford 9 inch Detroit Tru Track, Dakota Didgital, Vintage Air, QA1 Coil Overs Front & Rear Lots of FUN
2013 GMC PU, Oldest Son
71 GMC LWB. QA1 Suspension, Angry SB. Youngest Son
2019 GMC Diesil Dually. Youngest Son
2017 Toyota SUV Daughters car
2018 Traverse , Wife’s Ride
Pittsburg Ca
94565
1970 CST Short Wide is offline   Reply With Quote
Old 11-20-2006, 09:38 PM   #5
Bob Moore
It may just be the photo but the crossmember looks distorted or bent. It should be flat going across the rails. Those get bent very easily. That would cause the crank pully to hit.
I'm not saying it is bent but the photo makes it look that way.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 11-21-2006, 01:00 AM   #6
LockDoc
The Older Generation
LockDoc's Avatar
Bob: That crossmember looks that way from that angle. I think his is OK. (I had to go out and check my frame to make sure)...
prostreet1967: I tend to agree with 1970 CST Short Wide, my 454 is about an inch above that x-member at the front of the pulley with '72 BB motor mount towers.
LockDoc
Leon
Old 11-21-2006, 06:27 AM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I've seen a few back yard swps that had that area cut. Never looked into the reason though.
67 frames are a little different than later ones, but I', thinking it was width.
a short water pump might help, thats what was stock
motor mounts and the stands may be to blame.
Old 11-21-2006, 10:18 AM   #8
novajess1972
novajess1972's Avatar
I would agree. I just put the BB brackets/stands on in place of the SB brackets, and it does appear that the center mounting hole is higher. I have a 72.
Jesse
1985 SWB Silverado 1/2 Ton
1972 Chevy SWB 1/2 Ton (sold)
1972 Chevy Chevelle SS (sold)
1971 Chevy Nova (sold)
1967 Chevy El Camino (sold)
2001 Mustang Bullitt (sold)
2019 Toyota Tundra Crewmax (daily)
novajess1972 is offline   Reply With Quote
Old 11-21-2006, 10:53 AM   #9
prostreet1967
Jesse
so did you get the bottom pulley on without it hitting th crossmember
Old 03-28-2015, 11:53 AM   #10
CC Rider
I have the same issue on my 67 c10 with bbc swap. Previous owner torched clearance. Looking to replace with stock cross member to improve appearance.
CC Rider is offline   Reply With Quote
