SS454 wheels
I just picked up some SS454 chrome rims at a swap meet and was wondering if anyone else is running these on our trucks?
The caps are held on by outside threads on the lug nut but the lugs with it are metric. I have purchased standard outside threaded lugnuts for my 72 3/4 ton but those are a bigger thread. If anyone is running these and or knows where I can find 1/2" lugs with outside threads please let me know |
I have a set of those rims as well ( not on my truck ) due to the same problem. The only way I see it is to change the studs on the axles. The lug nuts that work just aren't made with the thread size our trucks use. At least I can't seem to find them...
Jake
68 SWB The Surgeon General doesn't say anything about smoking a Ford!!! Would rather be ran over repeatedly by a Chevy than drive a Ford!!! Paralyzed from the neck up and confined to a hat! Kathleen, Georgia USA |
This is a pic of a members truck, it looks like the same wheels to me.
His board name is Tom Hand. If this is the wheels you are looking to mount you might wanna give him a shout.
John Hutchison Grapevine,Texas 68 1/2 t swb 68 Mustang 69 Jaguar 71 1/2 t swb 88 Supra CompTs6m 93 Escort GT 2005 Corolla XRS |
I put a set of 1997 ralley rims (dually) on my 69 frame. The center caps are held on the same (external thread on the lug nuts). The rims came with the lug nuts. I bought all new metric studs, hammered out the old studs. enlarged (drilled) holes, hammered in new studs. Looks real nice. Didn't run into any problems at all.
72 Chevy A/C P/B P/S Tilt 454 Engine 400 TCI Trans C30 Frame C10 Suspension Short Wheel Base (Dually) |
you guy's might want to check out these sites. I think they have the lugnuts you need. www.nutstrimrings.html & www.stocktonwheel.com Hope this helps
CCRider
72 GMC Sierra SWB almost finished---- 84 Softail Olive Branch MS |
Thanks guys! Especially you tom hand.
ordered the lug nuts I needed Monday and they arrived today. I now have my SS454 rims on. The front center caps are alittle tight but it works
