11-20-2006, 02:35 PM | #1 |
Serpentine and E-fans
I have a 72 with a newly built 407 with the serpentine belt kit. Now I have almost no room for a fan I want to go electric but the distance between the bolts on the water pump pully and the radiator is 2.5 inches anyone else had this problem?
99 nbs 5.3L x-cab Hypertech programmer True dual 1 chamber flowmasters magnaflow x-pipe 3" PA body lift 315/75/16 BFG All Terrian 15.3 @ 89mph 72' C20 402ci sc,lb in bed tool box, and new paint http://www.cardomain.com/memberpage/456511/1 |
11-20-2006, 03:23 PM | #2 |
Re: Serpentine and E-fans
You can mount them as a pusher (from the front) or try to order a two fan set up with the water pump lining up to the center of the two. That might enable you to squeeze them in there. I have never seen one so close, did you mount it in the BBC position (the front holes in the frame) the SBC is supposed to be in the back holes.
