Old 11-20-2006, 08:29 PM   #1
71chevylowrider
71chevylowrider's Avatar
I need help adjusting Kickdown cable on a TH350
I swapped my edelbrock 1406 out & installe d aRoad Demon, now my truck doesn't kick down into passing gear, I know I have to hold the pedeal to the floor to adjust the kickdown cable, I just don't get how to adjust it, do you have to remove the cable from it's bracket? or is it that little tab on the cable directly in front of the bracket? (you can see it in the closeup shot) I'd appreciate it if anyone could tell me how to adjust it, thank you.
71chevylowrider is offline   Reply With Quote
Old 11-20-2006, 08:53 PM   #2
qksilver
Re: I need help adjusting Kickdown cable on a TH350
Is it still hooked up at the transmission end?
I have had one fall off after messing around with a new carb
qksilver is offline   Reply With Quote
Old 11-20-2006, 08:55 PM   #3
71chevylowrider
it's still hooked up, if I pull on it I can feel where it finally starts pulling on the linkage of the tranny. I never took it off of the bracket so it kept it from coming off down below
Old 11-20-2006, 11:56 PM   #4
jhow66
jhow66's Avatar
Pull up on the cable lock shown in photo-push pedal to floor-with petal to floor push the cable lock back down.
56 Chevy Bel-Air 2dr. HT (purchased new)
71 Chevy Cheyenne SWB PU (502HO)
65 GMC short bed step--work in progress and my gofer
jhow66 is offline   Reply With Quote
Old 11-21-2006, 12:23 PM   #5
71chevylowrider
Thanks JW, It's hard to see way back there, at least now I know what to pry up on.
