Old 11-20-2006, 09:30 PM   #1
AZgordo
Swapping rear ends...
I've got a 64 c-10 with a 308 and my son has a 68 c-10 with a 410. I want to get him better gas milage since his is a daily driver. Do you think they will just swap cleanly? They are both 6-lug wheels. WHat shuold I measure for this swap?
AZgordo is offline   Reply With Quote
Old 11-20-2006, 10:16 PM   #2
shortbed70
shortbed70's Avatar
Re: Swapping rear ends...
If you have a coil rear and coil rear all you should have to measure is the width of the axles from drum to drum. They should be the same I don't think they changed until 69 but maybe it was 68.
Troy
1965 Chevy Bagged,361 sbc,voodoo cam,1.5 full roller rockers,patriot 185cc vortec heads 2.02-1.60,vortec weiand polished intake,demon carb
my truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=332884
Big Red Dog build
http://67-72chevytrucks.com/vboard/s...d.php?t=572274
shortbed70 is offline   Reply With Quote
Old 11-20-2006, 10:22 PM   #3
Chevy Fleetside
Chevy Fleetside's Avatar
It will bolt right in... I put a 72 rear in my 65 and it bolts right in...
Chevy Fleetside is offline   Reply With Quote
Old 11-20-2006, 10:56 PM   #4
shortbed70
shortbed70's Avatar
I thought so I put a 68 gmc rear in my 65 and it was 1 in wider total width but gmc was ahead alittle chevy.
Troy
Big Red Dog build
Old 11-21-2006, 08:24 AM   #5
AZgordo
Thanks alot, good to hear it won't take much.
Appreciate the info.
Latz
Old 11-21-2006, 10:08 AM   #6
raggedjim
raggedjim's Avatar
The only thing you might check is the panhard bar and mounting. Some of the earlier trucks had a mount welded to the passengers side axle tube instead of the stup by the center housing, but I can't remember which years... But since you have both it souldn't be a problem.
I'll try to find a pic.
Rg
raggedjim is offline   Reply With Quote
Old 11-21-2006, 10:30 AM   #7
Chevy Fleetside
Rg
He is ok with the 64.. I believe it was the 60-62 that had it the other way...
Old 11-21-2006, 10:40 AM   #8
slepysal
slepysal's Avatar
so for a '60 rear end swap what would be needed? I have a line on '68 rear end thats been converted to a 5 lug, ez swap?
slepysal is offline   Reply With Quote
Old 11-21-2006, 08:25 PM   #9
zenish
azgordo the 63-64 panard bar is different from the 65-72 panard bar.you could use a track bar kit or maybe modify the 64 bar to work.the perches are in the right place.slepysal the 60 rear is different from 63 up rears.the perches are in a different place.
1964 c10 short step
1962 econoline van
1989 rs camaro
2006 yamaha vino 125
1975 goldwing
zenish is offline   Reply With Quote
