Question on a tilt column
I got this tilt column last week and noticed the arm for the shift linkage is offset, all the other ones I have seen are straight. Does this look familiar to anyone?
Chris 74 Custom Deluxe SWB 350/350/3.73’s 99 2wd Silverado RCSB 5.3/4L60/3.90’s http://www.classictrucks.com/feature...short_bed.html |
Roadtrip!
![]() Join Date: Feb 2003
Re: Question on a tilt column
I think the truck ones are straight. Looks like a van tilt to me. The plug in looks later also. Maybe someone who knows for sure can varify... Eric
67 gmc custom lwb dakota truck. Sold...And bought back 69 swb 4x4 project (in progress) 70 c-10 lwb texas truck 70 4x4/BB/bkts/posi/tach(retired) 70 swb (wifes) 70 jimmy camper 71 K-5 factory 2wd 71 cheyenne 4x4/tach/posi/ plow rig 71 Cheyenne20 BB, buckets, tach, tilt, 4 speed 72 jimmy CST wyoming rig 72 jimmy Colorado rig 72 lifted texas 4x4 3/4 ton burb 65 fury conv. 383/auto 65 chrysler 300 "L" 413 auto |
its all about the +6 inches
no, that's not a van, the shaft is too short. Vans had a straight shifter arm too. Maybe a RV or something?
it really shouldn't matter, there's enough room for movement, you should be able to just hook it up and forget it. |
68 C10 Longbed
![]() Join Date: Sep 2006
Wrong harness connector, and shift arm should be straight. But, the harness is an easy fix and the shift arm will probably work. Tilt RULES!
GM made/sold steering columns for Motor Homes, RV's, Industrial stuff---and I have seen many variations in both the harness, overall length, and shifter arms. You can adjust your lower steering column shaft length for just about any column and a harness adapter will allow for connection from/to any straight harness hookup. You should be good to go just make sure that your neutral safety switch location will work with your dash---most van's and some RV's require this to be relocated.
Thanks guys, I knew it wasn't a van column and I have the harness adapter, my main concern was the offset arm. I knew someone on here would have an answer for me!
The lettering on the PRNDLL is newer than 72. The shift lever is not P/U style but looks like a van.
The offset arm might work just fine by reversing the mounting of the rod retaining stud.
67 C-20 LWB, tilt, speed alert, vac, 454, T400 67 C-10 SWB, factory air with more to follow |
