Old 11-21-2006, 01:31 AM   #1
Brad
Out of the carpool lane.
Brad's Avatar
Question Can anyone id this proportioning valve?
This is out of a '67-72' truck, but I don't know what it goes to and whether it would work on my '67. I currently have the prop valve from a '77 down on the crossmember below the radiator and want to move it. Now that I think about it, I might be able to still use it and just use the bracket from this to mount it by the booster. Also, would I be able to media blast this clean again and just blow it out thoroughly before installing? Anyhoo, does anyone know for sure what this is from?
1968 C-10 SWB, 5.7 Vortec/700R4/3.73 posi, Torch Red
1968 Camaro, 250/Powerglide, all original (No, I'm not gonna drop a 350 in it!...Jeez!)
2000 Honda VFR in the faster yellow!
2008 Husqvarna TE-610
1967 C-10 SWB 'Six Appeal'-Gone but not forgotten...
Brad is offline   Reply With Quote
Old 11-21-2006, 05:26 AM   #2
Aarons72s
Re: Can anyone id this proportioning valve?
ok. That is a 71-72 disc brake proportiong valve. You could media blast it just be sure to plug all the holes with pipe plugs so no sand gets in there.
Aarons72s is offline   Reply With Quote
Old 11-21-2006, 05:29 AM   #3
Aarons72s
Here is a pic to help you out.
Old 11-21-2006, 07:53 AM   #4
70c10
67-72 Addict!
70c10's Avatar
Brad, that looks like the one I cleaned up last night . Mine came off a 71'. I used a wire wheel on a dremel to knock the rust off before painting.
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-21-2006, 01:10 PM   #5
Americanrider
Same as this one I pulled from a 71 C-30. The large port hanging off the bottom/rear is for trailer brake lines. More than likely it's from a 3/4 or 1 ton truck.
Americanrider is offline   Reply With Quote
