Old 11-21-2006, 02:11 AM   #1
409biscayne
409biscayne's Avatar
72 Trans mount crossmember
Quick question , if i'm changing from sbc w/t350 to bbc w/t400 is the trans crossmember the same ?? And in same location ?
Thanks............................. Doug
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 11-21-2006, 02:54 AM   #2
roj2323
Re: 72 Trans mount crossmember
yes it's the same but the location may be different. the nice thing though is it's easy to move. pull the bolts and give it a whack to slide it to the new location. heck if your good you can push the auto cross back far enough to clear the 400 when you put it in then just slide it into positon and bolt it up. this eliminates the struggle to remove and reinstall the auto crossmember.
ondrew
roj2323 is offline   Reply With Quote
Old 11-21-2006, 06:20 AM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
there should be holes already in the frame for your new tranny
