Old 11-21-2006, 08:20 AM   #1
70c10
67-72 Addict!
70c10's Avatar
Questions---Master cylinder and rotors
First question- when you install brand new rotors do you have to resurface the face of the rotor before installing?. I'm thinking it's not necessary.
Second question- I picked up my master cylinder last night for a 71' C/10 and want to make sure this is correct. Mine is the one with the gold cap but I have also seen people on here with the one that has the silver cap. Will the one they gave me work???
Thanks!
Jim
1970 C/10 Fleetside w/Ghost Flames
Lowered 4.5" front and 4" rear (Raked)
355/350 Turbo w/shift kit
10" Redneck Performance Verter w/2500 stall
Hooker Super Comps part#2808-1
Performer RPM Air-Gap
12 Bolt w/3:73 gears- Eaton Posi
Comp Cams XE262 with 1.6 Crane Energizers, Road Demon 625 and Brodix IK 180 heads
70c10 is offline   Reply With Quote
Old 11-21-2006, 08:36 AM   #2
underdog8704
NCStroker
underdog8704's Avatar
Re: Questions---Master cylinder and rotors
i have a 71 with the same cap. i have recently been looking for a gasket for the cap with no luck. the only ones i can find are in the gold cap's shape.
1971 Chevy C/10-Built 383 Stroker
underdog8704 is offline   Reply With Quote
Old 11-21-2006, 08:37 AM   #3
70c10
67-72 Addict!
70c10's Avatar
Does your 71' have the style in the pic on the left or right?
Jim
Old 11-21-2006, 10:03 AM   #4
byrd
Union Electrician
byrd's Avatar
Jim,
I would not resuface the rotors should be striaght anyway, a good cleaning with BPC should be just fine.
my booster and master combo that I have for my 69 has the same master as the one on the left.
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 11-21-2006, 10:08 AM   #5
cdowns
cdowns's Avatar
i like to gently block sand new rotors with 220 sandpaoer and then clean with brake clean
Old 11-21-2006, 10:43 AM   #6
msgross
msgross's Avatar
ditto, be sure to put that "anti-squeal" stuff on the back of your pads too! Less vibrations that cause squealing....
msgross is offline   Reply With Quote
Old 11-21-2006, 11:38 AM   #7
Zonaman
Zonaman's Avatar
Just converted my 69 to front disc brakes. Used brake cleaner for the new rotors, that's all. While we're at it, is the booster (1/2 ton) for drum the same as disc? Look the same to me. I know the proportioning valve is different.
69 C-10 LWB, 350, 700r4, 3.73 posi-traction, front disc brakes. Built for the desert- She can take the heat! Vivat Rex Chevus!
Zonaman is offline   Reply With Quote
Old 11-21-2006, 02:16 PM   #8
70c10
67-72 Addict!
70c10's Avatar
Thanks for the replies guys!
Jim
Old 11-21-2006, 02:29 PM   #9
underdog8704
NCStroker
i have the one with the silver cap. it is supposedly original. the gasket needs replaced due to some leaking, but i cant find a new one. where did you get your master cylinder from.
Old 11-21-2006, 03:22 PM   #10
70c10
67-72 Addict!
70c10's Avatar
I got mine at Autozone.
Jim
Old 11-21-2006, 03:54 PM   #11
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
It is a very good idea to roughen up the rotors, we take diegrinders and hit both sides of the rotor, just a scuffing, not actually to remove a lot of material. The indy car teams all do this, it helps to bed the pads in quicker and better stopping is the result.
As for your master cylinder, are both resivours the same size? I'm willing to bet the one you have is original to the truck...when it had drums. Disk brake masters should have a much larger resivour for the front brakes since the calipers uses fluid to adjust the brakes.
Old 11-21-2006, 04:07 PM   #12
70GMCer
70GMCer's Avatar
Jim call me up today.....Don't do anything to those rotors!!
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-21-2006, 06:15 PM   #13
Draggn66
Wrenchin & Sandin!!!
Draggn66's Avatar
Sooo what would the symptoms be if the wrong MS was installed? My 71 has disc brakes. The MS that was on there when I got it was like the one on the right. When I replaced it with one I bought at Napa they gave me the one on the left.
Randy
Shorewood, IL.
My Favorite eBay Searches
My Driver Restore Thread
1971 C10 Longbed
2005 Silverado Shortbed
2005 FXDWG
Draggn66 is offline   Reply With Quote
Old 11-21-2006, 08:51 PM   #14
Boog
laying low
Boog's Avatar
There are many varied opinions on new rotors and drums. I feel like a brand new part should be ready to install right out of the box. Several guys have told me they never put one on without trueing it on the grinder first. I have put on a few new rotors and drums. I ended up having to have them cut to get the pulsing pedal out of it. These were bought from CarPro and Napa stores. And they were Chinese. Maybe a new genuine GM rotor or drum is true right out of the box, I don't know.
At the very least maybe you should mount them and put a dial indicator up against them to check the runout before putting it all back together.
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-21-2006, 09:12 PM   #15
A.P.
Black 72 Chevy
A.P.'s Avatar
For new rotors, I just clean with brake cleaner and install them. Only when replacing brake pads I resurface the rotors. Recently I replaced the MC for my 72 chevy truck and it uses the one on the right, but I could not find the original. I ended up using the one on the left. So far I had not any problems. But then again I don't use my truck as a daily driver.
A.P.
A.P. is offline   Reply With Quote
