Old 11-21-2006, 05:58 PM   #1
Chevyman680063
Chevyman680063's Avatar
Carb. Problem
I have an Edelbrock 600 cfm electric choke carb. that i bought brand new a few years ago and for the last 6-8 months it has been giving me problems. Every few months it will start leaking gas out of the left side at the bottom underneath the throttle linkage. I have already replaced the base gasket about 3 or 4 times. Also, everytime it leaks it fouls out the sparkplugs, so I have had to replace the sparkplugs about 3 or 4 times. The carb. is not tightened down too much and it is not too loose either. It doesn't appear that the carb. or intake is warped either. I am seriously tired of having to replace the spark plugs because it adds up over time. The motor is a Chevy 350 smallblock and the intake is an Edelbrock as well. Does anyone have a clue as to why the carb. keeps leaking gas from the base? Thanks in advance.
Chevyman680063 is offline   Reply With Quote
Old 11-21-2006, 06:35 PM   #2
dwaite72lnghrn
Re: Carb. Problem
I would pull the top off and see if the carb has junk in the bowls. Sounds like the floats are not stopping the flow of gas and it is just overflowing. Could be a vent problem or a evap canister bad. You didn't say what year truck as some vent through cap and some vent through evap canister.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper
72 bug(the better half's) under reconstruction
2009 HHR aqua blue
71 GMC k20 350/sm465
2009 Chevy hd3500 6.6 Victory Red crew cab dually
Dave & Jeanne
dwaite72lnghrn is offline   Reply With Quote
Old 11-21-2006, 07:01 PM   #3
wedgemon
wedgemon's Avatar
Re: Carb. Problem
Check your fuel pressure. Eddy's like about 5 PSI. Also, check your floats.
- Dave
2003 Silverado K1500 Z71 - Arrival Blue
1973 K5 Cheyenne Blazer 350/TH350/NP203
Kids Trucks:92 K1500 Blazer 5.7/700R4 4" lift.
RETIRED: 1980 Scottsdale 4x4
Founding Member:
"TILT WHEEL BELLY." Club
wedgemon is offline   Reply With Quote
Old 11-21-2006, 07:57 PM   #4
Chevyman680063
Re: Carb. Problem
It's not the original motor. I believe it originally had an inline-6 in it. I thought about the floats maybe being the problem but haven't had a chance to actually check them out. If it is the floats then what should I do, just replace them?
