11-21-2006, 08:03 PM | #1 |
Tilt Hoods for 67-72
Does anyone know where I could find parts to convert to a front tilt hood on my 72? I've seen Autoloc's kit but it's a generic fit it yourself kit. Thanks for any info!!
Dan |
11-21-2006, 08:31 PM | #2 |
Re: Tilt Hoods for 67-72
most people just pull a set from a buick. i haven't seen a so called "kit" yet.
ondrew |
11-21-2006, 08:32 PM | #3 |
welcome to the board btw.
11-22-2006, 12:50 PM | #5 |
anyone figure out how to latch the rear of the hood yet without hood pins?
11-22-2006, 04:58 PM | #6 |
yeah ... same as the hinges ... Buick LeSabre latch
11-22-2006, 05:57 PM | #7 |
Here are the stock rear latches. It would take some fabricating since our hoods are wider in the rear so it could not drop down untill the last second. I will be getting about 3 sets of latches this friday and will play around with it abit. I will not be getting to it for about a month (cabs off the frame) but I will do a set up at that time.
Kevin LFD Inc. |
11-22-2006, 07:41 PM | #8 |
Insert Title Here
BOBBY _69 SWB_ 1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all << |
11-22-2006, 08:41 PM | #9 |
I just went to their site and read the instructions or lack their of. It is a universal kit that will require modification and they recomend that a fabrication shop do the install. I do like the simple design of the rear lock set up if I can not get the the one in the pic above to work. Yes the junk yard one is a universal fit that will also require modification as well but with the 1/2 off sale at the local Pick-N-Part it will only cost me $18 plus tx.
Kevin LFD Inc. |
