hey
so are the spot welds/little bit of sealant the only things holding the rockers on ??? if i drill the welds out willl the old rocker just fall off ? is there a write up on replaceing them ? thanks lance |
Re: rocker panels.........
Yes the spot welds are all that holds 'em on. And no, they won't just fall off, some prying, cussing and chiseling is required to get them off. I don't know of a write up.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
#3 | |
Weekend Warrior
basically drill out all the spots welds with a spot weld cutter - try to pry it off and find the spot welds that you missed, and the ones that you didn't cut "centered" re-drill/repeat and continue till the rocker comes off. Try not to damage anything else by bending and prying
-'07 GMC Sierra K2500HD -'66 C10 Suburban -'68/'71 K20 Service Bed Project -'69 Chevy C30 Mason Dump -'33Ford P/U 396ChevyPowered ![]() ![]() ![]() |
![]() Join Date: Apr 2005
Q check out my Burb link:
http://67-72chevytrucks.com/vboard/s...=200387&page=2 I just replaced the rockers and part of the floors on both side.
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
