![]() Join Date: Nov 2005
Core Support - repair or repop ?
What's your experience with aftermarket 72 core supports ? I need to do a little rust repair ( battery side ) on mine , plus sand blast and paint , might be cheaper to just replace . Whatta y'all think .
Tks ......................................... 409 ![]()
Can-Am Motorsports 37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser . 64 Biscayne 409 2x4 4 speed 4.11 posi 65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon) 68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD) |
Re: Core Support - repair or repop ?
Depends on if you have welding equip. I made a patch to replace the rusted area under the battery and sandblasted & painted mine, but then GMC supports are harder to find. Never used a repro support so can't comment on them.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction. ![]() ![]() ![]() |
I know truckandcarshop had them at our last swap meet for $125 so it seemed like a good deal.
![]() Join Date: Jul 2004
There is a patch panel available for the battery rust, I have done both ways and I would either fix the original, find a better original, last resort would be a repop, they take some work to get to fit, they are ok, just not an exact replica.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103 1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285 1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894 2001 GMC Sierra 1500 C3 6.0 |
Just make a patch and repair your own. Not very hard. Here is what I did.
