Old 11-21-2006, 10:48 PM   #1
6T9GMC
6T9GMC's Avatar
To Repair Or....not To Repair!
I Need Some Help! Here Is The Rust Problem I Am Facing. The Channel That The Wiring Loom Goes In Across The Top Of The Firewall Is Rusted... All The Way Across. Plus The Cab Has The Front Floor Panels That Have Rust. Is This Too Much? I Am Trying To See If It Worth It Or Not. I Thought About Just Cutting Off The Rust And Welding In A Thin Strip Across The Top To Reconnect The Firewall To The Cab, And Getting Rid Of The "guttered Out" Piece. Anyone?
6T9GMC is offline   Reply With Quote
Old 11-21-2006, 10:56 PM   #2
Boog
laying low
Boog's Avatar
Re: To Repair Or....not To Repair!
That reminds me of my 69 when I bought it. Basically a rust free truck EXCEPT the cowl area above and behind the heater case. Wasn't really enough there to seal the fan blower to. I clipped the cowl and found another truck with a good cowl but the rest of it was clapped out. What are the chances of that?
Thing is you may cut out the bad and repair it now but will the rust come back later?
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-21-2006, 10:57 PM   #3
roj2323
well unless your a metal god it would be far easyer to make it custom than keep it stock so i say cut out the cancer and weld in some new steel, shaving the rail at the same time. however before you go through all of this check the rest of the cab for rust. if it's really bad you may just want to concider replacing it.
ondrew
roj2323 is offline   Reply With Quote
Old 11-21-2006, 10:57 PM   #4
72CSTC5
72CSTC5's Avatar
Wow, looks like you need to look for a new cab. Multiply those areas times 4 to imagine how much rust is on the backside of the panels.
72CSTC5 is offline   Reply With Quote
Old 11-21-2006, 11:00 PM   #5
Green Machine
Green Machine's Avatar
I thought Oklahoma wouldn't have any rust that bad down there ?, depends on your time, money and skills. Surely you could find much better cab around there to use, just my 2 cents.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 11-21-2006, 11:47 PM   #6
HeavyD
HeavyD's Avatar
Yeah, considering where you live I would just hunt down another cab. Leave the rust repair to us northerners.
"You can take the man out of PA, but you can't take PA out of the man"
HeavyD is offline   Reply With Quote
Old 11-23-2006, 12:31 AM   #7
6T9GMC
6T9GMC's Avatar
Ttt
Old 11-23-2006, 12:59 AM   #8
qksilver
You are not far from AZ. By the time you went thru all that repair, money and time wise you would be ahead getting a good cab. Remember rust starts from the inside out. There is probably much more you can't see
qksilver is offline   Reply With Quote
Old 11-23-2006, 01:02 AM   #9
kndall
kndall's Avatar
just a suggestion.. your sig has a link to a graphic site, in the first 2 pics the cars have careys logos. If you do work fo rcareys see if they will do a trade for a cab, there is an orange and white one out there (air IIRC) that someone has already went thru and did rust work on. It prolly needs rockers put on it since it was sitting on the ground, they are prolly beat up.
I am a proud member of the "No, it's not for sale, I'm gonna fix it up someday" club.
kndall is offline   Reply With Quote
Old 11-23-2006, 08:02 PM   #10
6T9GMC
6T9GMC's Avatar
Ok, I'll Go Out There And Look. No, I Don't Really Do Work For Them, But For Some Of The Racecar Drivers That Carey's Really Helps Out Alot. Thanks.
