Old 11-22-2006, 03:47 AM   #1
71C-10DAD
71C-10DAD's Avatar
Question Couple of new questions for all my favorite helpers.
1st off thanks again you guys for all the help. Hope you all took a look at the pics that i posted. So you have some idea of what you are helping me with.
Now on to the questions.
1. Why when i get on the highway or interstate and go to get up to highway speed does it spit and spudder. When i reach 70 it doesn't do it. But if i am cruizing along at 70 and hit the gas it does the spit and spudder thing again till i let off.
2. What gears would give me a best acceleration and which would help improve my gas mileage.(Or do those go hand in hand.)
3. What do i need to do in terms of showing those mustang kids up. When i comes to lighting them tires up at a stop light?
4. What seat gives you the best big man fit when trying to keep it to where three can ride in the truck.
Thats what i have for now thanks again for all that answer back.
1971 Chevy C-10 .
71C-10DAD is offline   Reply With Quote
Old 11-22-2006, 03:55 AM   #2
krue
Designated A-hole!
krue's Avatar
Re: Couple of new questions for all my favorite helpers.
Answer to question no.2 is that they don't usually go hand in hand. For hiway speed driving a taller gear (lower number like 3.07 gears) is better. For acceleration a lower gear (higher number like 4.10 gears) is better. The lower gear also helps with "lighting the tires up".
Being stupid ain't illegal.
www.daveramsey.com
93 S-10 "Poppaw's Truck"
Old 11-22-2006, 03:59 AM   #3
71C-10DAD
71C-10DAD's Avatar
ok how do i tell what ones i have seems that they would be stock. when i try to power brake it. It wont even move a spin the tires. Bougs down bad.... if i went with some 3.73's would that put me in between?
1971 Chevy C-10 .
Old 11-22-2006, 08:29 AM   #4
arkracing
Weekend Warrior
well some more information is really needed to help answer the gearing and "bogging" questions.
#1. is the motor stock? - what is it?
#2. do you just want a "Red light racer" or do you want some "cruisability" too? (i.e. a set of 4:10 gears will get you off the line a lot quicker - but will hurt highway performance and gas milage)
to see what gears you have you can see if you rear end has a little tag on 1 of the cover bolts - and get the numbers off of that - you'd be lucky if it is still there.
you could pull the cover and count the teeth on the gears
or you could make a mark on a spot of the "Yoke" (where the driveshaft attaches to the rear end). them make a mark as close to the center of the axle as posible (but it is still able to "Make a circle" when you turn it. them count how many times the yoke has to turn to get the axle to turn 1ce. (so a 3.07 gear would be just over 3 turns of the yoke to 1 turn of the wheel -etc)
NOTE this method isn't entirely accurate but will get you a close guestimate
As far as the seat thing goes - i'm under the firm belief that the stock bench seat fits best and is actually very comfortable (provided that the foam padding is in good shape)
-'07 GMC Sierra K2500HD
-'66 C10 Suburban
-'68/'71 K20 Service Bed Project
-'69 Chevy C30 Mason Dump
-'33Ford P/U 396ChevyPowered
arkracing is offline   Reply With Quote
Old 11-22-2006, 08:32 AM   #5
stingray72
Red Headed Step Child
stingray72's Avatar
I'm 6'1 and I use the stock seat. It's comfy for me. I've got a smaller than stock steering wheel which I think makes a difference. Only thing i'd ask for is a touch more legroom
"Dinner, the perfect break between work and drunk"
-Homer Simpson
stingray72 is offline   Reply With Quote
Old 11-22-2006, 08:36 AM   #6
Bench seat from 88-94 Chevy truck is great. Very comfortable and supportive. To me it's much better than the stock ones.
