11-22-2006, 09:55 AM | #1 |
Power steering pump help?????
This may be a dumb question, but that has never stopped me before . I have swapped my SB350 for a BB468. I am buttoning everything up and I can't fit the power steering pump from the 350 onto the BB! The holes look like they line up, but maybe it's just the bracket??? I am hoping like heck that SB and BB P/S pumps aren't different. But then again, I had no idea that SB and BB motor mount brackets were different until just last week Any feedback on the P/S pump issue greatly appreciated.
Thanks Jesse
1985 SWB Silverado 1/2 Ton 1972 Chevy SWB 1/2 Ton (sold) 1972 Chevy Chevelle SS (sold) 1971 Chevy Nova (sold) 1967 Chevy El Camino (sold) 2001 Mustang Bullitt (sold) 2019 Toyota Tundra Crewmax (daily) |
11-22-2006, 11:00 AM | #2 | |
Re: Power steering pump help?????
11-22-2006, 11:10 AM | #3 |
Are you using a long or short water pump?
11-22-2006, 11:12 AM | #4 |
brackets are different from a SB to a BB
11-22-2006, 11:20 AM | #5 |
Long water pump
Jesse
11-22-2006, 11:21 AM | #6 |
The pumps or the brackets? Or both? Jesse
1985 SWB Silverado 1/2 Ton 1972 Chevy SWB 1/2 Ton (sold) 1972 Chevy Chevelle SS (sold) 1971 Chevy Nova (sold) 1967 Chevy El Camino (sold) 2001 Mustang Bullitt (sold) 2019 Toyota Tundra Crewmax (daily) Last edited by novajess1972; 11-22-2006 at 11:21 AM. |
11-22-2006, 11:22 AM | #7 |
But the same pump can be used????
Jesse
11-22-2006, 11:23 AM | #8 |
Go get these at the dealership. I'm using them on my 72. They are about $35 or so.
3967422--bracket 14015391--bracket 3967424--spacer |
11-22-2006, 11:24 AM | #9 |
Yes, same resivour(SP?) and pump can be used. You just need the right brackets.
*EDIT** One other thing that might get you is the later year pumps used an "O" ring style seal compared to the earlier "Flare" style seal. Last edited by ratrod67; 11-22-2006 at 11:26 AM. |
11-22-2006, 11:27 AM | #10 | |
WOO HOOO!!! Thanks, Ratrod67!!! Now onward to the next obstacle...LOL Jesse
11-22-2006, 12:38 PM | #11 |
hey rat rod u have any pics of how all the brackets go on i tore my motor apart couple years ago can't rember how they went back on
11-22-2006, 01:37 PM | #12 |
11-22-2006, 02:07 PM | #13 |
here you go found these pics helped me out should help once u get the brackets
11-22-2006, 02:08 PM | #14 |
those pictures are for a big block pump about 40 dollars at local parts store
11-22-2006, 02:08 PM | #15 |
not sure if they work with small block pump let me know if they do
11-22-2006, 02:28 PM | #16 | |
Jesse
11-22-2006, 02:40 PM | #17 |
11-22-2006, 04:55 PM | #18 |
there is absolutely NO difference in the pumps between a small block or a big block for our model trucks, the difference is in the brackets ONLY.
early style (late 50's thru mid 60's) pumps had 3/4" in shafts with NO keyway and the pulleys were pressed on. later (mid 60's up) style pumps had a 1/8" keyway in the pulley ... unsure of shaft size, this was pretty much the standard pump until GM went to the serpentine pulley/belt system ... and some claim the only difference then was the pulley, I can't say. I have a ZOOP'S press on 3/4" shaft single groove pulley if you are interested, it is polished billet FORGED aluminum , not the Cheap Chinese cast version. Let me know if you're interested & I can get you a pic or two. Last edited by Shane; 11-22-2006 at 04:57 PM. |
11-22-2006, 06:34 PM | #19 |
Novajess,,,dont mean to hijack,been watching & learning thru your questions,,I'm doing the sbc to bbc swap right now myself,,,just ordered the brackets that RatRod mentioned,,from GMPartsDirect.com,,,$23.83 +$12.21 for handling ,,,thought this might help you out ?
I'm using the P.O.L. motor mount stands,,the motor mount themselves are $7.95 each at O'Reilly,,,part # Anchor 2267,,,however I havent got them installed yet,,waiting on some parts for the rat motor.May have some clearance issues too? Hope this helps out ? Thanks RatRod & everbody for the good info. JFD |
11-25-2006, 09:48 PM | #20 | |
The motor mount stands I got from Outback Truck Parts worked beautifully! I just wish that the price was as beautiful ($171 total) But we do we we gotta to get our babies on the road again. Let us know how your project goes!!! Jesse
