Old 11-22-2006, 11:22 AM   #1
1LIME69
1LIME69's Avatar
Another tilt question
This is probably a stupid question, but I have a chance to buy a late 70's pickup tilt column with all new internal parts for 300.00 and I want to know if it will bolt straight up to my 69' c10.
1LIME69 is offline   Reply With Quote
Old 11-22-2006, 11:32 AM   #2
Bob Moore
Re: Anothe tilt question
I would recommend a van tilt rather than a later P/U column. The diameter of the P/U is larger requiring the gauge cluster plastic be modified, the wiring is different, the key on the column, and the shaft exiting the firewall is different requiring the 73+ intermediate shaft. Some people have done this swap but I really think the van tilt is a better option.
67 C-20 LWB, tilt, speed alert,
vac, 454, T400
67 C-10 SWB, factory air with
more to follow
Bob Moore is offline   Reply With Quote
Old 11-22-2006, 11:34 AM   #3
1LIME69
1LIME69's Avatar
Thanks for the info Bob, what year van columns will work?
Old 11-22-2006, 04:06 PM   #4
70GMCer
70GMCer's Avatar
You can buy them late 70's pickup tilts all day for around $40.00. I sold one not too long ago for $25.00. Just wanted it gone. You want the van tilts up to 1981. They have the key in the dash like our trucks.
1997 GMC Sierra Ext
1965 Mustang
70GMCer is offline   Reply With Quote
Old 11-22-2006, 05:14 PM   #5
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
72 - 81 and a hand full of 82's
Old 11-23-2006, 12:32 AM   #6
1LIME69
1LIME69's Avatar
That helps me alot, thanks guy's!
Old 11-24-2006, 02:56 AM   #7
hogrocket
Junior Member
I just finished putting a tilt from a 75 truck in my 72. The bigger column fits under the plastic dash cluster without modification. Use the firewall brace from your truck in place of the later model one. I have a manual shift, so I ground the shifter nub and ignition switch nubs down , took out the inners for shifting and steering wheel lock and used JB Weld to fill the holes. Painted up it looks like a stock tilt column for a standard truck. You can buy a wiring harness adaptor from the dealer for about 8 bucks. You also have to lengthen the column about 2 inches by sliding out the sleeve. Also, I had to use a little creativity with the under dash mounting bracket. Not a big deal. So although it's a little more work, these columns can be used and are a viable option. However, I would not pay 300.00 for one just to tear it a part. Like 70GMCer said, you can buy them all day long for 40.00. A van tilt may be easier, but they seem to be getting harder to come by.
hogrocket is offline   Reply With Quote
Old 11-24-2006, 11:11 AM   #8
hotrod 80
mini truck racer
hotrod 80's Avatar
I did the van tilt yesterday . Bought the column from a board member for $125 shipped to the door . I have a 68 with a 3 speed column shift . I had to move the reverse /neutral safty switch down by the fire wall . Did it by hand , except for a cordless drill , in less than 3 hours . With the 2nd gen camaro 4 spoke wheel I bought off ebay , i have about $150 and 3 hours work tied up in the whole conversion . I vote van tilt , looks factory .
hotrod 80 is offline   Reply With Quote
Old 11-26-2006, 06:06 PM   #9
1LIME69
1LIME69's Avatar
Re: Another tilt question
I'm on the look out for a van tilt. Thanks for all the helpful info.
