Old 11-22-2006, 02:35 PM   #1
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
ok i got a few questions
ok on my 68 gmc which was a factry small block truck..was told a 307,,but not sure on that..but any way
question 1: if i decide to use the 454 out of my 84,,is it a pretty much drop in, will the motor mounts from the 84 work, or am i going to have to find some.
2) should i use the 350 turbo that came with the truck or go with the turbo 400 i got laying around. now the truck will not be a heavey hauler,,or work truck..i will use it for pulling a travel trailer,,if and when i get one..
3)what year spindles can i get out of junkyard to get disk brakes up front.
4)what gears should be in the rearend..personally im not worried about take off,,i need mpg,,or at least better than the 5 to 8 i get in my 84.
anything over 10 and i will be happy.
heres the vin number
CE10DPB49417
IS THERE A PLACE I CAN LOOK IT UP..
im not restoring the truck..i want a daily driver..i dont worry about mpg to much,,but would like better then my 84 work truck..man that 5 to 8,,(closer to 6) is rough, but i knew when i bought the truck what to expect...
i want a truck i can play with, probably just gonna put it in primer, maybe the rat rod look for now,,eventually put a paint job on it...but it will never be a show truck or trailer queen..i got it to drive...i am going to get pics of it now
billy
honestly honey,,i have no idea how that truck got here.
68GMC454 is offline   Reply With Quote
Old 11-22-2006, 02:47 PM   #2
Blue85
Oilfield Trash
Blue85's Avatar
Re: ok i got a few questions
hi, and welcome to the forum from canada,
answer to question 1)i think you can use the 84 motor mounts, if you adapt the 84 frame mounts to fit your truck, click here http://67-72chevytrucks.com/vboard/s...d.php?t=128765.
#2, personally i would use the th400 , but you will probably have to change your driveshaft, the th350 will probably hold up with a trans cooler though,
#3, is the truck a 1/2 or 3/4 ton?,
#4, if i had to guess its probably a 3.08 rear, have you checked the glovebox option sheet? it should say a gear ratio on it
14 Dodge 3500 Mega Cab
08 Dodge 3500 Mega Cab
87 Chev 3+3 4x4
80 GMC K10 High Sierra bone stock
70 Chevelle 350SS long term project
68 GMC 3ton Grain Truck/Garbage wagon
50 Pontiac 2 Door Coupe Project
"I've got a shotgun rifle and a 4 wheel drive and a country boy can survive" Hank Jr.
Blue85 is offline   Reply With Quote
Old 11-22-2006, 02:59 PM   #3
Blue85
Oilfield Trash
Blue85's Avatar
btw here is the palce to look up your vin http://www.gmcpauls.com/67-72_gmc.htm
87 Chev 3+3 4x4
Old 11-22-2006, 04:32 PM   #4
CPNEJR
CPNEJR's Avatar
if you look on the glovebox door it will say the rearend gear. if it doesn't then it is a 3.73
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 11-22-2006, 04:34 PM   #5
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
oh ok i forgot,,1/2 ton...will have to look in the glove box...thaks for the info
so is the 400 longer or shorter than the 350 turbo..
so from the vin nunber i know its a 2wd, v8, 1/2 ton, wide side, made in pontiac, and a 68
thanks..now is there a site that has optons for the truck,,such as color,,engine choices...
thanks
billy
Old 11-22-2006, 05:13 PM   #6
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
If it is a small block with auto, and no option lited, then it is a 3.07, not a 3.73.
How big of a trailer you looking at tugging on?
Old 11-22-2006, 06:11 PM   #7
68GMC454
THE VILLIAGE IDIOT
68GMC454's Avatar
im looking for up to a 24 foot camper,,any bigger and i should probably just use my 84..this is why i cant decided to pull the 454 out of my 84 to put in my 68..i luv my 84,,needs better mpg,,but its a work truck...
