Rez Power Steering kit HELP PLEASE ASAP
I just got the Rez power steering kit from GMC Pauls and it seems me that it is not fitting right. I have attached some pics to help further explain my situacion and would appreciate anybody's help.....The problem #1- the top right hole is no aligned with solid metal, the pic and explanation in the directions show the bracket and the top hole aligned in a place on the frame that will allow you to drill it out. Not the case for me #2- the bolts included in the kit are not long enough to go through the frame. My frame is a stock 2wd but it is boxed from the factory in the spot were the bolts go through......anybody have this problem? Help please!!!!Thanks for the replies
Re: Rez Power Steering kit HELP PLEASE ASAP
if thats a 1960-62 chevy,cpp sells the correct kit for your truck.that frame is nothing like my 64.
1964 c10 short step 1962 econoline van 1989 rs camaro 2006 yamaha vino 125 1975 goldwing |
It a 1962 Fleetside....hope to find a solution
#4 | |
![]() Join Date: Oct 2006
I would sugest calling REZ up and see what they say . |
After I ran into the problem and tried to solve it I cleaned up the manual box and all the associated bolts....it is in great shape and the worst case scenerio is that I reuse my original box.......but I am holding out hope.....what is the full name of the other company I should check out...CPP stands for what? thanks for the help guys
Classic Performance Products http://www.classicperform.com/
id make pauls give me the right kit.
Update ? What hapened?
I have solved the problem and will post some pics in the next couple of days.....It has been a process but I think it will work out great...
So did it work out ok ?
