Old 11-22-2006, 10:59 PM   #1
1967j
1967j's Avatar
rear suspension
For 5 inch drop springs in the rear would i need to c notch the frame? and how does blocks effect the suspension? would 5 inch springs on 1 inch blocks need c notching? thanks for help j
P.S if anyone has lowered long bed pictures or trucks on 20's feel free to post, im trying to find how low to go. - and yes iv seen the wheel tire fitment post befor
1967j is offline   Reply With Quote
Old 11-23-2006, 01:36 AM   #2
powell72
powell72's Avatar
Re: rear suspension
You wouldn't need to notch the frame for either the 5'' or 6'' rear drop. There's nothing wrong with getting 6'' with a 5'' spring and 1'' block. The other items you'll need will be shock relocators and a super track bar kit for the 6'' or an adjustable bar for the 5''.
Chris
74 Custom Deluxe SWB 350/350/3.73’s
99 2wd Silverado RCSB 5.3/4L60/3.90’s
http://www.classictrucks.com/feature...short_bed.html
powell72 is offline   Reply With Quote
Old 11-23-2006, 01:46 AM   #3
1967j
1967j's Avatar
Re: rear suspension
Thanks,for that.
Old 11-23-2006, 02:25 AM   #4
1967j
1967j's Avatar
Re: rear suspension
now i just need to decide on how much drop to go :P
Old 11-23-2006, 02:33 PM   #5
powell72
powell72's Avatar
Re: rear suspension
How much are you planning on dropping the front? Is it drum or disc? If it's drum are you planning on converting? I'm assuming since you want to see longbed pics that's what your truck is, 3/5 kits look good on them, plus you get 1'' extra travel than with the 6''.
Chris
Old 11-23-2006, 07:36 PM   #6
1967j
1967j's Avatar
Re: rear suspension
yes i was thinking more 2.5 spindals on 1 inch drop springs
on 5 inch or 5 and 1 inch block its just hard to see drop and 20's on lwb not too many. drum-drum now but goin with front conversion
