Old 11-22-2006, 11:29 PM   #1
SNEAKYPETE
what would it take?
i have a 72 2wd jimmy that i would like to put on 22" wheels and air bag, I plan on using a porterbuilt crossmember, air rides tubular a arms, but i am wondering about inner fenders, hood hinges, how much of a notch i will have too do too the rear, i want it to sit low, but still run a rear seat, how low can i go without cutting the rear floor? thanks for any input
SNEAKYPETE is offline   Reply With Quote
Old 11-23-2006, 02:13 AM   #2
Rokcrln
Rokcrln's Avatar
Re: what would it take?
With out cutting the rear floor you can only go with a C notch and that will put you low but not real low. What I would do is run porters Dropmember and then step your flor the same amount that your rear seat mount is high. Then bolt the seat right to the floor. That should get you an extra 6"+ in the rear.
Here is a notch I did for a customer that was mesured by first figuring out when the diff would hit the floor then doing a notch to match.
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
