Old 11-23-2006, 02:18 PM   #1
409biscayne
409biscayne's Avatar
Dash pad swap .
Is there a Faq tech on swapping the dash pad ? I didn't see one , it's been years since i last swapped one and i'm thinking it wasn't too much fun . Especially with a/c , etc. Someone point me in the right direction .
Tks .................................... 409
Can-Am Motorsports
37 Chev Coupe 331 4 speed 5.13 posi . ex-gasser .
64 Biscayne 409 2x4 4 speed 4.11 posi
65 Nova Wagon Drag Car 383 t400 (Dragin-Wagon)
68 c10 cst 396 t400 a/c buckets lwb 4.11 posi (SOLD)
409biscayne is offline   Reply With Quote
Old 11-23-2006, 02:33 PM   #2
72GMCburban
72GMCburban's Avatar
Re: Dash pad swap .
Did u remove the old one? If not, start by removing the front screws, I would take out the the instrument panel 1st, u will need to anyway. Then get all the nuts off the bolts, they are in the dash, so u will need to go through the defrost vests or up fron the underside, the easiest ones are in the glove box, after u take out the glove box that is 6 or 7 total. Then just replace with the new one and rebolt and screw it in, then replace the panel and the vents and glove box. Took me about 45-60 minutes to remove, with no guidance.
72GMCburban is offline   Reply With Quote
Old 11-23-2006, 02:36 PM   #3
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Dash pad swap .
the center nuts, overr the center A/C vent is a real PITA.
Honestly. I only install the outer 2 nuts (3/8 socket IIRC) and the screws on the outside.
Old 11-23-2006, 07:40 PM   #4
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
Re: Dash pad swap .
A quarter in drive socket set helped me a lot.I did remove the glovebox and loosened the dash cluster to tilt it forward out of the way.If you haven't replaced A/C and heater defroster hoses this is the time to do it since it will be easier to do the dash pad with them out of the way.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-23-2006, 07:57 PM   #5
CPNEJR
CPNEJR's Avatar
Re: Dash pad swap .
most of the time the factory didn't even install the center nut and you will want to replace the pad before you replace the ducting because it will be a b*tch to do with them in
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
