Old 11-23-2006, 02:19 PM   #1
corn
Where can I find this heater hose fitting?
Ive checked a couple parts houses but I cant find a 45 for this heater hose. It had a straight up fitting but it puts a little bind on the heater hose & I think it would look better at a 45. Anyone know where to buy these?
corn is offline   Reply With Quote
Old 11-23-2006, 02:39 PM   #2
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: Where can I find this heater hose fitting?
napa. Ask for a brass 5/8 hose elbow
Old 11-23-2006, 02:54 PM   #3
corn
Ill check it out. Thanks...
Old 11-23-2006, 04:09 PM   #4
QKENUF4U
QKENUF4U's Avatar
yep any hardware store should have a brass fitting that will workin that hole
QKENUF4U is offline   Reply With Quote
Old 11-23-2006, 04:22 PM   #5
corn
Will it be one complete fitting or will it look like an erecter set when its done? Id like to find a one piece deal...
Old 11-23-2006, 04:58 PM   #6
QKENUF4U
QKENUF4U's Avatar
im thinking ive seen/had in my had a one piece 45* fitting (brass)
Old 11-23-2006, 06:36 PM   #7
neonlarry
neonlarry's Avatar
I get mine here:
http://performancesst.com/customer/home.php?cat=26
70 C/10 Light Red 350/TH350, HEI, Duals w/40 series Flows, 91 seat, LED taillights
99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs
95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI
neonlarry is offline   Reply With Quote
Old 11-23-2006, 07:44 PM   #8
corn
Thats exactly what Im looking for but Im WAAAAAAAAAY to cheap to pay $30 for one...
Old 11-23-2006, 08:58 PM   #9
Sweet72
Sweet72's Avatar
Galvanized 1/2" NPT street 45 and 1/2" NPT/hose barb all at True Value for about $1.00. How's that for cheap, oh and a piece of bailing wire to secure the hoses to your perty braided fuel line and your all set!
Seriously though, that stainless fitting is rediculously expensive! I need a set for my 383 too and should go to NAPA and check.
'72 GMC SWB C1500 Custom, frame-off in progress. 383 SBC, 9:1CR, Comp Cams XE262H, Scat internal balanced crank, Eagle SIR 6" rods, Keith Black dish pistons, Dart Iron Eagle 72/180 heads, Weiand Stealth intake, Stewart stage I water pump, Holley 4bbl vac sec, TH350 with B&M Shift Improver Kit. 12 bolt positraction.
Sweet72 is offline   Reply With Quote
