Old 11-23-2006, 03:58 PM   #1
sixtysevengmc
village idiot
sixtysevengmc's Avatar
VIN # locations
can anyone tell me the location of the vehicle identification number on the frame of a 1967 GMC?(I'm assuming chevy may also be the same)
also,need to know where it is located on the cab?
I can't find the vin plate on mine,I think it should be on the driver side door jamb.....but I'm not sure.pics would be helpful and appreciated
Thanks,
James
sixtysevengmc is offline   Reply With Quote
Old 11-23-2006, 04:04 PM   #2
byrd
Union Electrician
byrd's Avatar
Re: VIN # locations
stamped of the top of the DS frame rail near the steering gearbox is one for sure and I thin they are stamped again in both rails under the cab, not totally sure on that one though
69 Custom-10 SWB FLEETSIDE 350/350 TH Dropped 3.5/5.5"
Help support the board->HERE
Board vendors -> Vendors list
Zip:40272
Big Sandy Survivor...
We cannot choose the way we die, but we can choose the way we live
If you can't fix it with a hammer, you've got an electrical problem.
I think Congressmen should wear uniforms like NASCAR drivers so we could identify their corporate sponsors
byrd is offline   Reply With Quote
Old 11-24-2006, 04:03 AM   #3
Americanrider
Re: VIN # locations
67 GMC's had a small tag on the drivers rear jam, about 1.5 ft up from the rocker.
Americanrider is offline   Reply With Quote
Old 11-24-2006, 07:38 PM   #4
sixtysevengmc
village idiot
Re: VIN # locations
have any idea where the #'s are on the frame?
I cant seem to find one near the steering box......
the one on the cab is missing.
Old 11-24-2006, 10:03 PM   #5
Rod
Re: VIN # locations
67 was known to not have any vin numbers on frame.
Senior active founding member.
70 3/4 ton GMC Suburban 4x4 250/4 spd.
71 1/2 ton Suburban Chevy 4x4, 350/350
72 Chev 1 ton tow truck 402BB w/Holmes 440 wrecker on propane
2005 FLSTSCI Harley Springer
85 FXSB Harley Lowrider
72 Triumph 650 Bonneville 5spd
"Poor people don't have hobbies" Quote from wife.
Rod is offline   Reply With Quote
Old 11-24-2006, 10:08 PM   #6
Rod
Re: VIN # locations
but typically they can be seen at this location....the famous longhornman finger
Old 11-24-2006, 11:26 PM   #7
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Re: VIN # locations
With as much as my hand has been pimped... I shoulda washed up.
Old 11-25-2006, 03:45 AM   #8
Americanrider
Re: VIN # locations
On my 67 Chevy K20 it's on the outboard side of the frame about 12in behind the steering gearbox. (green circle) I'll look at my 67 GMC's tomorrow and repost.
Old 11-25-2006, 02:29 PM   #9
sixtysevengmc
village idiot
Re: VIN # locations
I appriciate all the help
Old 11-25-2006, 04:59 PM   #10
68shortfleet
Re: VIN # locations
Anybody have any pics of the door jamb vin tags. Were they just stamped, or were the numbers/letters highlighted with any paint? Mine were completely painted over in a terrible shade of a metallic blue. I am stripping the paint now, but do they need some kind of repaint.
Jason
68shortfleet is offline   Reply With Quote
Old 12-20-2006, 12:07 PM   #11
silvertonguedevil
silvertonguedevil's Avatar
Re: VIN # locations
I want to say that the tags were painted and stamped. I'm not at home right now to look at mine but I'll do that and let you know.
-Greg
My Chevy trucks, past and present:
1962 C10 SB Fleetside
1964 C10 LB Fleetside BBW
1966 C10 SB Fleetside
1966 C10 SB Fleetside BBW
1968 C10 SB Fleetside
1971 C10 LB Fleetside
1971 C10 SB Fleetside
1972 C10 SB Fleetside Cheyenne
1972 C10 SB Fleetside Cheyenne Super
1972 C10 LB Fleetside Cheyenne Super
1974 C20 Cheyenne
1979 K5 Blazer Cheyenne
1982 K10 SB Fleetside Custom Deluxe
1982 K10 SB Fleetside Scottsdale
1986 C10 SB Fleetside Silverado
2008 Silverado 1500 4x4
silvertonguedevil is offline   Reply With Quote
Old 12-21-2006, 12:51 AM   #12
Aarons72s
Re: VIN # locations
The original ones where chrome metal, at least the 67-69? ones I have seen. the 70-72, the big vin plates I think are stainless or aluminum. They use some sort of ink for info and lettering except the vin, which is just stamped on it. Sorry I forget which year went from the small vin plate to the big plate.
Aarons72s is offline   Reply With Quote
Old 12-21-2006, 08:58 AM   #13
extd56
extd56's Avatar
Re: VIN # locations
My 67 GMC had the small vin plate on the B pillar on the drivers side and no frame numbers on the frame.
extd56 is offline   Reply With Quote
Old 12-21-2006, 10:35 AM   #14
sick69
sick69's Avatar
Re: VIN # locations
I beleive the 69 was the last year for the little vin plate.my 69 had 2 small plates and my 70 has 1 large plate.
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 12-21-2006, 12:09 PM   #15
Olden Days
Living In The Past
Olden Days's Avatar
Re: VIN # locations
Jason
One of mine had been painted and I was able to clean it up pretty good with that "goop off" stuff. I was worried it would take off the original colored writing that is not stamped in but it worked out pretty good.
I guess it depends on the year as to if it has colored writing though. My 72 had the vin and a couple of other things embossed with the rest all in blue writing. My 70 has no color with everything on the plate embossed
Olden Days is offline   Reply With Quote
