Old 11-23-2006, 04:40 PM   #1
ChevyFan24
Junior Member
5.3/4L60E swap questions?
I have a parts truck that I pulled the 5.3 and the 4L60E from yesterday. Before I take the truck back I was wanting know if there was anything else I need to keep off of the 2001 Silverado. I have the engine, trans, manifolds computer and all off the wiring. I am going to take out the accelerator cable and the trans cable Friday.
Has anyone used the OEM radiator and a/c condensor from the 5.3?
Goodies from ECE should be here Tuesday! 4/6 drop, hidden hitch, sway bar kit, and LS/5.3 motor mounts.
Happy Thanksgiving!
ChevyFan24 is offline   Reply With Quote
Old 11-23-2006, 07:03 PM   #2
70shortnphat
"See the U.S.A....."
70shortnphat's Avatar
Re: 5.3/4L60E swap questions?
Get the 02 sensors from the exhaust.
1970 short bed fleetside
1949 all origional chevy 3600
1974 camaro
Richmond , Texas(just S.W.of Houston)
70shortnphat is offline   Reply With Quote
Old 11-23-2006, 07:09 PM   #3
Misstur_big
Junior Member
Misstur_big's Avatar
If you are going to make it emmissions legal you will need the evap canister.
Also get the fuel line ends so you can retro fit them to your lines. Take the drive shaft...you need the yoke. Take the P/S lines..you need the pump fittings.
Do your self a BIG favor. throw away the factory harness and buy one from painless. Trust me on this! Take a look at my thread. I just finished a 5.7L 4L60 in a 67. You will be happy you went this way if you do it smartly
Misstur_big is offline   Reply With Quote
Old 11-23-2006, 07:11 PM   #4
Misstur_big
Junior Member
P.S. You wont be able to use manifolds unless you set the engine way back. If you are going to use small block towers and LS1 mounts than you will have to use headers
Old 11-23-2006, 10:56 PM   #5
ChevyFan24
Junior Member
Thanks for the input. I forgot about the yoke on the drive shaft. I'll put that in the garage also. I cut the exhaust before the cats so I have the O2's. I thought I read that someone was using F-body manifolds? They are cheaper than headers and usually seal better. I also have about 24" of the fuel lines from the engine towards the tank. I am not worried about emission but I will grab the vapor can/box as well. I have one of the PS lines the other was missing? I have talked to Painless and Speartech for new harnesses. I like that Painless is a very well known company but Speartech is 2 1/2 hours from me? Decisions, decisions?
Old 11-24-2006, 07:21 AM   #6
blazerboy72
I had wait4meperformance.com do my harnesee and reprogram. They were the cheapest place I could find and they did a good job.
blazerboy72 is offline   Reply With Quote
Old 11-24-2006, 09:22 AM   #7
Kid
Kid's Avatar
Speartech is a great co. I used theirs on my project, took 10 minutes to hook up & fired right up with no problems. I had John rework my computer also. they also made my harness custom just like I wanted layed out with the computer in the cab. I suggest you keep the fuel pump (in tank) from the truck,I ended up using a factory Trailblazer pump, but your PU pump might be usable.
Kid is offline   Reply With Quote
Old 11-24-2006, 11:07 AM   #8
N2TRUX
Happy to be here
N2TRUX's Avatar
Originally Posted by Kid;
..... I suggest you keep the fuel pump (in tank) from the truck,....
You can use an external mount pump as well. It's a lot less hassle than trying to retro fit an internal pump.
A lot of things have changed since we did my 82 Blazer LS1 conversion 4 years ago. I use Fuel Injection Specialties to mod my OEM harness and computer. They did excellent work, and were a great help over the phone when info was needed. They also have a chassis dyno to do any tuning you might need after the install.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 11-24-2006, 11:47 PM   #9
ChevyFan24
Junior Member
Kid- Thanks for the input. The original fuel pump was sold out of the truck before I got it.
balzerboy72- A friend told me to use Wait4meperformance also. He used them for a reflash on his Silverado.
N2TRUX- I am considering an external pump. Did you use an external pump, if so what brand? Thanks.
The 5.3 & 4L60E are sitting in the chassis waiting for the ECE engine mounts.
Check out the pics. Do you think it was to early to try to put the grill in!
Old 11-24-2006, 11:49 PM   #10
1969k10stepside
What part of Indiana are you in?
1969k10stepside is offline   Reply With Quote
Old 11-24-2006, 11:50 PM   #11
ChevyFan24
Junior Member
Sorry about the second pic. It looks good on my camera?
Old 11-24-2006, 11:52 PM   #12
ChevyFan24
Junior Member
Southern Indiana
Old 11-24-2006, 11:53 PM   #13
1969k10stepside
East,west?I am by Vincennes.
Old 11-24-2006, 11:55 PM   #14
ChevyFan24
Junior Member
Central. Harrison County. I am in Vincennes occasionally for work.
Old 11-24-2006, 11:57 PM   #15
1969k10stepside
Welcome to the site,btw I am glad there is finally a Indiana member not on the complete opposite side of the state
Old 11-25-2006, 12:04 AM   #16
Rokcrln
Rokcrln's Avatar
You might want to check into using the rear end and disk set up as well if it is a half ton!
Kevin
LFD Inc.
Rokcrln is offline   Reply With Quote
Old 11-25-2006, 12:16 AM   #17
ChevyFan24
Junior Member
1969K10stepside- Thanks for the welcome. This site is excellent. Your sig show parts? Do you have a good SWB bed? (at least good floor and braces)
Rokcrln- The rear end was already sold and the truck is in my driveway on stands. The neighbors love it! I am considering disc brakes for the stock rear end.
Old 11-25-2006, 12:20 AM   #18
1969k10stepside
The only swb bed I have now is on a trailer in my backyard for the 71 SWB K10.I know of another swb bed in town and if I get it I will let you know.When I subscribe(which I will shortly) I will be selling alot of parts.
Old 02-05-2007, 11:50 PM   #19
Terry'sToy
I'm kinda late here, but I modified my passenger side frame mount, and used LS1 exhaust manifolds(as I had the LS1 motor). I also used Speartech. I used an external pump with a 72 return style sending unit for the return line. Can't remember the name of the pump. It needs to put out 60psi. I extended the return line to the bottom of the tank to help prevent fumes. I used the camaro rad and dual fans in my truck, my dads 67 is going to use the stock 67 rad as the 5.3 I'm putting in his truck has a fan on front.
Enjoy
69 GMC 1/2 ton lwb, LS1, headers X-pipe 4L60E Yank 3500 stall 3.73 w/eaton brute force. moroso trick front springs,jeep rear springs, QA1's
Terry'sToy is offline   Reply With Quote
