Hollister, CA.
![]() Join Date: Sep 2006
No turn signal indicators on the Rockabilly ?
So just curious...why doesn't my '63 have turn signal indicators on the dash ??
![]() ![]() Did a '63 have no dash trun signal idicators ?? Thanks John
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
Hollister, CA.
Re: No turn signal indicators on the Rockabilly ?
Anyone ?!?!
I think the hole you covered up is the signal indicator. I don't think there's a left and right, just one bulb that blinks no matter which way you're signaling. Not sure if that is 100% accurate, but that's the way it is in my '62, and it was pretty unmolested when I got it.
I have no idea. but If thekid54 is correct you had better pay attention how you wire it! By connecting the wires for a turn signal together there you may end up turning on the flashers every time you hit a turn signal!
#5 | |
My 62 is like that as well, and IIRC, I have a dash out of a 60 or 61 that is the same way...
2000 GMC CCSB 454/4L80 6” lift SAS 1999 Chevy CCSB 454/NV4500 6” lift 1999 GMC Yukon 350/4L60 4" SAS |
#6 | |
Hollister, CA.
If that is the case, then the hole I covered up is also missing a cardboard tube as well as the socket. The harness has a L & R wire..if that bulb was to flash with either side, then the harness should of been wired that way...... but it has two seperate wires. Anyway, someone added one of those external "Signal-Stat" turn-signal swicthes....which has a bulb that flashes for either side. Like I said I was just curious about the fact that I had two wires, and no place for them to go !!! John
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" Last edited by ChiefRocka; 11-25-2006 at 01:30 PM. |
UCA63
As thekid54 said
my '63 has one indicator for l&r signals Maybe the wires are from a '64????
member#7816 "63 sb ss bbw 350\350 12 bolt rear Pwr Fr Disc PS tilt '61 GMC in progress '63 GMC to use for parts '90 Chevy Ext cab sbfs 5.7l (current d d) |
#8 | |
Hollister, CA.
Who knows what they did. Anyway, I was just curious as this is the first old school C-10 I've owned. I'll just leave the light in the Signal Stat Thanks guys....... John
my 66 had a R and L signal light on the dash. i couldn't find mine but ended up shining a light behind the gauges and saw the indicators.
My 63 is the same way. From my recollection some of the early trucks had only one indicator. Look at it this way, if a light is blinking, it is either left or right. I just think it is another cool feature of these trucks. It was a simpler time!
