Old 11-24-2006, 08:37 PM   #1
69lowNlong
no brakes...look now
ok well i picked my truck up today and when i drove it there was no brakes... to get the truck to even slow to a stop i had to down shift and seriously pump the brakes and then hold them to the floor! i am going to do a major overlook of the truck and bleed the brakes tomorrow but tonight i was seeing if maybe anyone had any ideas? hopefully none of the lines are rotted or broken... thanks guys!
69lowNlong is offline   Reply With Quote
Old 11-24-2006, 08:38 PM   #2
bagged_gmc
Shaved
bagged_gmc's Avatar
Re: no brakes...look now
Yikes!
bagged_gmc is offline   Reply With Quote
Old 11-24-2006, 08:42 PM   #3
CPNEJR
CPNEJR's Avatar
check the wheel cylinders to see if they are leaking if they are you should replace them and also buy a rebuild kit for the drum brakes
(Only) Member of the CPNE Fan Club Aint that the truth
67 C-10 350 with 3-speed tranny and 308 gears swb step
82 Z28 Camaro 355 small block over 350 hp and a borg warner super t-10 (blown engine)
72 Chevy K20 Suburban (future project)
70 Chevy K20 now 68 GMC K2500
2003 Chevy 2500hd ccsb 4X4 (daily driver)
CPNEJR is offline   Reply With Quote
Old 11-24-2006, 08:44 PM   #4
69lowNlong
where woul a good place to get that for the best price?
Old 11-24-2006, 08:51 PM   #5
CPNEJR
CPNEJR's Avatar
we usually get them at napa
Old 11-24-2006, 08:53 PM   #6
PanelDeland
I am a Referee of life.
PanelDeland's Avatar
69, don't worry about price on brakes or steering or suspension.Try your local auto parts store.They should have everything you need.Some will have to order it but should be able to get it in a couple of days.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion.
You can't fix stupid,not even with duct tape.
"My appearance is due to the fact that "GOD" does punish you for having too much fun!"
Barrett-Jackson has perfected alchemy,they make rust into gold!
"You can lead a horse to water but you can't saddle a duck"
"Cleverly disguised as a 'Responsible Adult'
"Sometimes your Knight in shining armor is just a retard in tinfoil"
PanelDeland is offline   Reply With Quote
Old 11-24-2006, 08:55 PM   #7
1969k10stepside
I would check the master cylinder.
1969k10stepside is offline   Reply With Quote
Old 11-24-2006, 08:57 PM   #8
69lowNlong
well i got all day tomorrow i plan on checking everything! you guys think bleeding the system will improve the brakes
Old 11-24-2006, 08:59 PM   #9
1969k10stepside
My 69 K10 had the same conditions,new lines,and new drums and the master cylinder was what was bad.I bled them about every weekend and would have pressure for awhile then the pressure would deteriorate.
Old 11-24-2006, 09:01 PM   #10
69lowNlong
just check for leaks or you wouldn't see anything visible on the master cylinder would you?
Old 11-24-2006, 09:25 PM   #11
qksilver
Don't drive on 95!
qksilver is offline   Reply With Quote
Old 11-24-2006, 09:32 PM   #12
xmitsu10
xmitsu10's Avatar
The 69 I just bought in Sept had no brakes either when I got it home. Pulled the MC but it was fine. All 4 wheel cylinders were not leaking. The front brake line that goes across the crossmember to the RF wheel cylinder was severly corroded and leaking near the T block. The crossmember was packed with dirt and it was soaking up the brake fluid so there was no leak on the ground. Your line may be fine but something to check if MC and wheel cylinders are good.
71 Cheyenne SWB
xmitsu10 is offline   Reply With Quote
Old 11-24-2006, 09:38 PM   #13
my67C10
my67C10's Avatar
if you do wind up replacing something i would go to napa they usually have next day delivery.
my67C10 is offline   Reply With Quote
Old 11-24-2006, 11:29 PM   #14
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
hope you're dealing with a 1/2 ton... 3/4 ton and one ton trucks would get real expensive... real fast.
Old 11-24-2006, 11:51 PM   #15
truckdude239
truckdude239's Avatar
advance can normally if they don't have it over night it
David fuller
Ase Certified Mechanic
Click here to help support our board!!
1971 Chevy c-10 under going a 4.8l LSx swap
Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=421305
2007 Honda Accord my daily 145kmiles
2002 Honda Accord 4 door With 330k(sisters car)
2005 toyota Avalon 228k( brothers car)
2002 Sububran 5.3 245k
2000 Tahoe 5.3l 378
General manager for Marco's Carwash & lube
truckdude239 is offline   Reply With Quote
Old 11-25-2006, 05:12 PM   #16
69lowNlong
well i looked it over and found a pin hole leak on the passenger side right at the upper arm! so quick fix got a new line and fitting and bled all the brakes and it is good to go the truck runs and drives good as hell plan on lowering soon and taking care of some body work!
Old 12-01-2006, 10:58 AM   #17
69lowNlong
hey everyone thanks for the quick responses!
FOR SALE 69 c10 LWB...best offer
