Old 11-24-2006, 11:48 PM   #1
kna4977
How hard is it to change a water pump on a 99 Tahoe?
My water pump needs to be changed as it is leaking and making noise. Is this something I should do myself or have someone else do? If I should do it myself, does anyone have any tips? thanks
kna4977 is offline   Reply With Quote
Old 11-25-2006, 09:39 AM   #2
Grande Rojo
paper or plastic?
Grande Rojo's Avatar
Re: How hard is it to change a water pump on a 99 Tahoe?
If it has the 5.7 its real easy. What motor is it??
Grande Rojo is offline   Reply With Quote
Old 11-25-2006, 10:24 AM   #3
kna4977
It's the 5.7
Old 11-27-2006, 09:56 PM   #4
Big Block
Big Block
Big Block's Avatar
Does it have the original radiator hoses and water pump bypass hoses? Now might be a good time to change them. The bottom radiator hose clamp is a little tricky. Its pretty tight down there.
Big Block is offline   Reply With Quote
Old 11-27-2006, 11:31 PM   #5
kaycee
kaycee's Avatar
Seperating the fan from the pump can be a pain allso, I used a oil filter strap wrench to hold the pulley and then broke the nut loose.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 11-28-2006, 11:27 AM   #6
bcj67chevy
402 BIG BLOCK
bcj67chevy's Avatar
They do make a fan clutch tool that can be rented that makes it a lot easier to take the clutch off. After you get the clutch off its a breeze.
1967 C10 swb
1970 GMC Jimmy 4x4
2005 Chevy tahoe Z71
2001 Chevy impala
bcj67chevy is offline   Reply With Quote
