Old 11-25-2006, 03:21 AM   #1
earl87gta
earl87gta's Avatar
Your Suspension opinions wanted
I was going to take a 2wheel drive frame that had power steering and cut the frame off and weld it in place of my 68 4x4 so that I could have power steering. But now Im thinking about using the hole frame and keep the coil spring rear or air bags, and use a coil spring front end out of a new doge for the front. Or should I keep it the way it is with leaf springs and just add the power steering . What do you guys think. The coils on all 4 corners would be different and would probably ride great I could even do air in the front. I don’t plan on doing a lot of off roading with it it will be more of a toy towing trailer every once in a while.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 11-25-2006, 08:03 AM   #2
see ten
WTB this ad
see ten's Avatar
Re: Your Suspension opinions wanted
Unless I am mistaken all you have to do is bolt on a power steering box from anything all the way up to like 1987. Of course it must be from another 4x4. I can't remember which is which but one box has a pitman arm that moves front to back and the other has one that moves from side to side. The only time you should be putting a 2wd box on a 4wd frame is during a crossover steering conversion.
see ten is offline   Reply With Quote
Old 11-29-2006, 03:49 AM   #3
earl87gta
earl87gta's Avatar
The frames are diffrent thier dimpled in you can heat up the frame an beat in the dimple or you can cut one off of a 2nd frame to use. IM using a 2 wheel drive box for cross over steering on it. the biggest reason I want the 2wd frame is so I have some place to stick the body why I build the new drive trian or to use as a starting point for the build. Just cant decide if I want to keep the 68 origanl or build something totaly diffrent.
Earl
Old 12-01-2006, 02:02 PM   #4
earl87gta
earl87gta's Avatar
here is a pic of a 71 and a 68 frame at the steering box you can see the 68 is strait and flat and the 71 has a bend to clear the steering box.
Earl
