Old 11-25-2006, 01:10 PM   #1
dishow
dishow's Avatar
front end help
ok,pardon my ignorance,but i need your help on this one.......
the "bracket" that is between your upper A arm and frame(upper a arm bracket???)what exactly does this do.mine is rotted out pretty bad on both sides and need to know how to go about getting new ones.I looked them up in LMC(pg.116)but they are"shaded"and not available thru them. you guys ever run into this?thanks.
90 Chevy 454 ss
Old 11-25-2006, 01:25 PM   #2
BarryB
BarryB's Avatar
Re: front end help
Without a picture it is kind hard for me to tell. My lmc catalog pg 116 is the waterpumps and fans.
but if it it was I am thinking about, it holds your upper a frame to the frame itself.
BarryB is offline   Reply With Quote
Old 11-25-2006, 01:34 PM   #3
st1x10
st1x10's Avatar
Re: front end help
I would need a pic to know what "bracket" your talking about. In fact I might have one at home. I will have to check when I get off of work.
1970 Chevy C10 "Under Construction"
2002 Chevy S10 V6
st1x10 is offline   Reply With Quote
Old 11-25-2006, 01:36 PM   #4
LONGHAIR
Re: front end help
If you are refering to the bracket that the upper control arm shaft is bolted to....the 2 bolts that have the alignment shims on them, they are considered part of the frame assembly itself. You may have been able to get them as crash repair parts many years ago. It is not likely now though. They are welded to the frame and not considered "wear-out" items. If you really need to replace one, you are probably going to have to find a donor truck and be prepared to do some surgery.
LONGHAIR is offline   Reply With Quote
Old 11-25-2006, 01:39 PM   #5
GMCMAX
Active Member
GMCMAX's Avatar
Re: front end help
Try this NAPA link-http://www.napaonline.com/masterpage...ont+Suspension
Never try to teach a pig to sing; it wastes your time and annoys the pig!
Gets More Chicks
My lugnuts require more torque than your honda makes!
68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4".
GMCMAX is offline   Reply With Quote
Old 11-25-2006, 03:41 PM   #6
dishow
dishow's Avatar
Re: front end help
hi.Thanks LONGHAIR,thats exactly what Im talking about.........and thats what I was afraid of. Thanks to all.
90 Chevy 454 ss
