will a stroke fit in a 72
if you ever wondered if a powerstroke will fit in a 72 truck, it does. it is tight and i still have more work ahead of me and alot of cleaning on the motor, but it does fit and i did sit the cab down over and there are clearence issues with the transmission touching the firewall. and the turbo touches the firewall. so i lifted the cab up 3 inches and it all clears. so you could cut into the firewall, but if its a lifted truck you could do a body lift. im going to add a 2x3 box tube across the top of the frame and raise all body mounts up to match. and adding the box tube and a nice new crossmember under the motor and i think it should have plenty of stregnth. but i first need to finish my 2wd shorty, got my new 468 going in soon. so i need to get my frame blasted and reassembled first.
Re: will a stroke fit in a 72
Nice, gotta love the torque of those diesel motors.
Well, that is truly a different project you have there.
Some will say you have comitted the "ultimate sin" of a ford motor in a chevy truck; of course if that is a 7.3 it's really an international motor as opposed to a true ford engine. Good luck and post pics of the other project also.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() |
laying low
![]() Join Date: Mar 2001
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
blood type; Retumbo
so then WHEN you need to replace the injectors you will have to remove the cab? or are you gonna have access holes in the firewall to get to the oil galley plugs?
now for some rib-jabbing fun. I think those powerstrokes are a very efficient engine. they do a great job of converting diesel fuel into smoke and noise. LOL |
#6 | |
its all about the +6 inches
My argument that always shut up the local diesel guys...
let me put a turbo on my 500 like you guys have... and then we'll have a little tug-o-war. ![]() I just did a little MPG test on our power-joke at work and was rather disapointed. 96(ish) F-250 4X4 (7000 pounds) with a flat bed that has a tall front wall. I did a 100 mile of straight freeway at 60 - 75 MPH, minimalhills, and another 80 miles of 75% freeway. Yes, I do launch it like a top fuler, but like I said, this was very much mostly freeway. This sucker only got 12 MPG. it has new injectors as of 4000 miles ago, and a new cam sensor as of 10,000 miles ago, and has 160k showing on it. I was rather shocked to see such crappy MPG. |
I have bad thoughts of building a 72 Tahoe 4dr and setting it over my 99 PS running gear and frame! Now that I know it will fit
![]() For the post above~ Mine has 156k and I get 18-21mpg and I am not easy on it, I love the turbo spool sound! Kevin LFD Inc. Last edited by Rokcrln; 11-25-2006 at 11:26 PM. |
#9 | |
The older 7.3 got ok mileage...........The worst though(Atleast the majority opinion held my many, me included in my area) is the Duramax. Key to good fuel mileage is not running them like a gasser, you don't need to stand on it at leaving from a stop, and a stick is a must for economy with a diesel............Around here in the mountains it kills the mpg quick, the auto that is, they always want to downshift and put the rpm's through the roof, with a diesel that is not needed(Well, maybe except on some of GM's earlier experiments
![]() ![]() That engine actually fit better than I thought it would.............I'll have to keep that in mind next time I might have to do a swap............A 7.3 PS with a ZF-6spd would be an ok setup ![]() ![]() For anyone who cares.............Alot of guys on the net tell me a cam position sensor from a electronic IH-DT466 cures them of needing it replaced from what seems to be all the time, and its cheaper from an IH dealer than Ferd.
'72 K-20 EFI'ed 250 Inline/4spd stake body, Farm Truck '71 C-20 Cummins Diesel Powered, In storage thanks to $5.00 diesel! '69 3500 GMC 305V-6/4spd, Still under reconstruction.......... Inlines Rule! 6 soldiers standing is better than 8 laying down!!!!!!!! |
I have a 2000 7.3 PSD that gets from 18 to 22 unloaded and about 16 loaded.
Truck has been 100% trouble free for 6 years now. I have pulled every thing from a 6000 lbs camper to 6000 lbs of quarter horse mares and the PSD always keeps cranking out decent mileage and trouble free service.
ongoing 1970 c 10 lwb ![]() 1994 z-28 few mods.-owned since new ![]() 1978 vette silver/grey 25th anniv. paint ![]() Last edited by chevybill; 11-26-2006 at 01:16 AM. |
Just sold mine and had a programmer, exhaust and intake with small lift and 35's 4wd. Never got more than 13mpg loaded or unloaded but would pull like you wouldnt believe. Miss that truck dearly, bought it new. The girlfriend works for Enterprise Leasing so she can drive one whenever we want so....... Goodbye truck.
#13 |
Guess you will need a front axle also to move the diff over and something more beefy than the dana 44.
72 longhorn c30 502BB/th400/fact air/4.11rear/ custom camper 72 bug(the better half's) under reconstruction 2009 HHR aqua blue 71 GMC k20 350/sm465 2009 Chevy hd3500 6.6 Victory Red crew cab dually Dave & Jeanne |
#14 | |
and i made more progress today not really on the 72, but the clean up of the remains of the stroke. after i clean up the motor with a pressure washer im going to cover it all up, and store it for the winter. and through the winter i will finish my frame off on my 67 2wd shortbed. and finish up the stroke around the end of summer. but atleast i got a nice jump on my stroke project. got the whole frame and supension cut into three peices and stuffed into the bed of my s10. ![]() and the cab and bed on a little trailer, luckily i dont have far to go. ![]() Last edited by rancid; 11-26-2006 at 08:56 PM. |
#15 |
turbo enthusiast
"But daddy, I didn't hit them all with a stick"...what my 6 year old tells me when I pick him up from school early for fighting ![]() |
#16 |
Well Hey Guys, I am biased I am a cummins fan. I get great mileage. last I checked it was right at 19 MPG. And that is not light footing it either. I too like the sound of a Turbo spooloing up. And I also have straight exhaust. OH YEAH!!!
