11-25-2006, 06:08 PM | #1 |
I did my wheel cylinders
I have few questions I bleed the s**t out of them the pedal is a little lower but it brakes hard and firm so I think I will leave it maybe bleed it more later.
Question Do the bleed screws weep a little for a while? I made 3, 5 minute trips and after the first there was some fluid around bleed screw, second less third a lot less just like one little drop. Thinking it maybe fluid in the bleed screw it self running out I think my last truck with disks did the same thing for about a week?
1968 c10 lowered 3" 4" 355/Th400 built by Hatfield racing in joplin MO |
11-25-2006, 07:01 PM | #2 |
laying low
Re: I did my wheel cylinders
Make sure the brake shoes are adjusted up good. This will raise the pedal some.
Boog 69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver primer is finer 91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said. I stand for the flag and kneel at the cross |
11-25-2006, 07:28 PM | #3 |
I adjusted untill they barely dragged on the drum. If I backup and stop some will the selfadjusters kick in?
11-25-2006, 07:33 PM | #4 |
11-25-2006, 10:16 PM | #5 |
blood type; Retumbo
when adjusting shoes I usually run them in tight and then back off about 8 or so clicks. that way you know both shoes are at the same setting.
