#1 | ||
Brake bleeding kits.
Are these worth a dam?
[1] http://www.harborfreight.com/cpi/cta...emnumber=92924 [2] http://www.harborfreight.com/cpi/cta...emnumber=92474 [3] http://www.harborfreight.com/cpi/cta...emnumber=37201 Thanks
Re: Brake bleeding kits.
I have #2 and find it useful not only for brakes but things like checking vac advance or checking for leaks (pull a vac and watch for leakdown).
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
I had #3 and it was junk.
I have one like #2 and it seems ok. I need to bleed my rear brakes to see for sure how well it works, but it seems easier than the old fashioned way.
NOT REALLY BANNED!
![]() Join Date: Jul 2004
Just go to Oreilly's and spend $22 on the one man bleeder screws.
1987 Mustang Coupe - 2.7 Stroker, 78mm turbo, Stainless header, 3" Exh, FMIC, 160lb/hr Injectors, MS3, twin walbro 255's, 34psi. Eating V8's daily. 04 Pontiac GTO 04 Ford Mustang GT 68 C20 LWB stripper truck 73 K5 Cheyenne 76 C20 Sierra Crew SRW 88 K20 Suburban I'm not hammering on metal just to hammer, i'm creating a piece of art. |
#6 | ||
I am a Referee of life.
I use one similar to #3 it works ok but probably not as fast as the others.
The 47-present Chevrolet and GMC Truck Message Board Network,it's owners,moderators,members,and associates of any type should not be held responsible for my opinion. You can't fix stupid,not even with duct tape. "My appearance is due to the fact that "GOD" does punish you for having too much fun!" Barrett-Jackson has perfected alchemy,they make rust into gold! "You can lead a horse to water but you can't saddle a duck" "Cleverly disguised as a 'Responsible Adult' "Sometimes your Knight in shining armor is just a retard in tinfoil" |
just get a MITY-VAC (harbor freight carries them for like 28-34$ but you can get them lots of other places also) and you will never have bleeding problems again. i put new wheel cylinders on the back and had perfect brakes in 15mins.
JUST MAKE SURE YOU DONT EMPTY YOUR MASTER CYLINDER !!!!!!!!!!!!!!!!!!!! Last edited by QKENUF4U; 11-26-2006 at 12:24 AM. |
#9 | |
NOT REALLY BANNED!
Sure am, they're awesome.
Mity-Vac ... you'll need nothing or no one else.
