Old 11-25-2006, 09:02 PM   #1
Axle Code
I was cleaning the rear of the truck today and was looking at the codes numbers I found on the rear axle. Is this the right code to look up to see what gears I have. The first two letters doesn't match anything that I have for the 69/70 model year
This code came off the passenger front side of the pumpkin housing
NF3896838
Old 11-25-2006, 09:11 PM   #2
72dually
72dually's Avatar
Re: Axle Code
You need to get the #'s off the front passenger side axle tube, that will tell you everything, including date and gear code
70 GMC shortbed fleetside with a 72 chevy costume
72dually is offline   Reply With Quote
Old 11-25-2006, 09:15 PM   #3
Boog
laying low
Boog's Avatar
Re: Axle Code
Only if the gears haven't been changed though..
Boog
69 Chevy stepside, 358/T350, 4.11 posi, 4.5/4 drop, rallys, poboy driver
primer is finer
91 Chevy sportside, Tahoe, Yukon & GMC Crewcab All GM..'nuff said.
Old 11-25-2006, 09:43 PM   #4
Re: Axle Code
That's what I thought, but I had never seen a clean one before and numbers in this location so, I thought this mught be it. Time to get dirty again tomorrow.
Old 11-25-2006, 09:50 PM   #5
72dually
72dually's Avatar
Re: Axle Code
Yep , your going to have to get a little dirty. A wire brush should do if it hasn't been re-painted. If you slide in front of the passenger rear tire, it will be around the middle of the tube.
