Adding power brakes
If I wanted to add power brakes what all would I have to do? I'm under the impression that all I have to add is a booster behind the master cylinder. Is there anything else I would have to do?
1968 C-10 longbed, 307 V8, 4spd- currently under construction ![]() ![]() |
Re: Adding power brakes
Just make sure you get the whole setup between the brake pedal and the master(clevis pin & rod, bell crank, bracket, rod for booster, booster & rod for master).
Then very carefully move your master cyl forward far enough to get the bracket and booster in without kinking the brake lines.
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
The Older Generation
If your suspension is stock that should be correct. Be sure and get the firewall mounting bracket and all linkage with the booster. LockDoc
So how much do you think all of this cost if I were to get it new? Do you think if I picked some of it up at a salvage yard that it would be any good or is it something you have to buy new?
Active Member
Did mine recently, bought here on the parts board, I think like $50. If you get the whole set-up here or the salvage yard, you can get a rebuilt booster from the parts house and use the old one for a core.
Never try to teach a pig to sing; it wastes your time and annoys the pig! ![]() ![]() My lugnuts require more torque than your honda makes! 68 GMC, 4X4 conversion w/73 k20 running gear and springs, 350 4spd, 4.10's, D44 powerlok front, 14BFF govlock rear, 33" tires, lifted 4". |
Except for the booster itself none of those parts are likely to be found new.
Dave's not here, man
What year booster are you planning on getting? I think the 71-72 boosters will bolt up to your truck, but I'm not sure about later years. I just did this with a booster/m.c. from a 79 and the brackets and rod length had to be modified to fit. It's not a lot of work if you have a shop, but my shop is the great outdoors so it presented a few problems.
- 2014 VW Jetta - 2015 VW Jetta - 1966 Ford F-250 |
