11-26-2006, 02:07 AM | #1 |
Garage Queen Material
water out my exhaust
ok, i have a question/possible problem.
after about 1 minute of running, the exhaust starts spitting out quite a bit of water, enough to leave a little puddle under the pipes. after about 10 minutes it no longer emits water though. its not coolant, or fuel, just dirty water(dirty from the carbon in the exhaust pipes) i know some water is normal, but this just seems like its quite a bit more than the "normal" like i said, i know its water, and not coolant or fuel. i dont have a head gasket leak or anything, its just water... |
11-26-2006, 01:22 PM | #2 |
Re: water out my exhaust
It sounds like your engine is tuned properly and catalytic converters are working well. The result of burning hydrocarbons (aka - dead dinosaurs, gasoline) using oxygen extracted from the ambient air is nitrogen (and a lot of it), carbon dioxoide, heat, and water.
Of course, this assumes complete (0% wasted fuel) combustion without any contaminants in the fuel like sulfur. Internal combustion engines fall far short of this utopian ideal, but they are improving all the time. As far as your truck is concerned, I wouldn't be a bit concerned about significant water escaping the tailpipe when you first start up the engine. Your exhaust system has not warmed up enough to keep the combustion water vaporized, and it is condensating inside the exhaust pipe until everything warms up sufficiently. This will be aggravated when the outside temp drops. This is the primary reason modern exhaust systems are made from stainless steel, aluminized steel, etc. Corrosion from the inside is a big problem.
79 GMC Sierra Grande K15 --PPG paint code 62608 Sunburst Orange Metallic (WA802K) --Gentex auto-dimming rearview mirror model K31 --Carriage Works billet grille model 40071 --Go Industries 2.5" tubular stainless headache rack --Sylvania Silverstar sealed headlights model H6024ST --Texas Saddlebags center console model 101 --Brown's Welding class IV V-5 pipe bumper --Ramsey RE8000 winch --33" tires Last edited by bmartin9122; 11-27-2006 at 01:07 PM. |
11-26-2006, 01:25 PM | #3 | |
i know water out the pipes is normal, but it just seems like a lot of it. |
11-26-2006, 03:10 PM | #4 |
Parts and more parts
Condensation is a miracle of nature. Add moisture laden air and then heat it up and then cool it again the water will collect and run out of your exhaust. Winter is coming---Dude.
11-26-2006, 05:48 PM | #5 | |
The increase in water at your truck's tailpipe is most likely due to the seasonal drop in ambient air temperature. No worries!
79 GMC Sierra Grande K15 --PPG paint code 62608 Sunburst Orange Metallic (WA802K) --Gentex auto-dimming rearview mirror model K31 --Carriage Works billet grille model 40071 --Go Industries 2.5" tubular stainless headache rack --Sylvania Silverstar sealed headlights model H6024ST --Texas Saddlebags center console model 101 --Brown's Welding class IV V-5 pipe bumper --Ramsey RE8000 winch --33" tires |
11-26-2006, 07:36 PM | #6 |
If it continues on a warm day or there is evidence of steam out of your pipes, along with a sweet smell, then there would be concern about a leak.
11-26-2006, 09:50 PM | #7 | |
7000 #'s of american IRON
On cold mornings, sometimes i'll get a cloud out of both pipes (true duals with H pipe) aong with water. Just condensation is all it is. |
11-26-2006, 10:04 PM | #8 |
I HATE winter. Ever since I used to have to push snow for a living. Frostie and his winter friends are not on my list of goodies.
11-26-2006, 10:23 PM | #9 |
comfortably numb
I live about 80 mi. east of you,near Henryetta. all my cars do the same thing. if it does it after a 30 min. warm up, I might get concerned. It's just our humid weather.Just be sure you warm it up good. Short trips wil rot your pipes and muffler out quick.
11-26-2006, 11:57 PM | #10 |
Kid's Mechanic
its normal
11-27-2006, 02:14 AM | #11 | |
