Old 11-26-2006, 04:15 AM   #1
Corellian Corvette
Need pictures of proper Jack storage on '74 K20. Can't figure it out.
I found a couple of Jack Parts behind the seat on my 74 Cheyenne.
The Jack Handle is mounted to the passenger side inner fender, but I'm not sure how to mount the Jack and the longer handle. I can sort of see in the jack instruction pictures online but not good enough to see exactly how it goes.
Can anyone post a couple pics of the proper setup in their cars?
Also, I think you need some sort of "C" shaped bracket to hold the jack down against ther fenderwell. This part I can't find anywhere (which is probably why the P.O. put the stuff behind the seat). Does anyone reproduce that bracket?
Also, are their any other parts I need?
Thanks!
Corellian Corvette is offline   Reply With Quote
Old 11-26-2006, 10:47 AM   #2
cliffsta
Stepsides RULE
cliffsta's Avatar
Re: Need pictures of proper Jack storage on '74 K20. Can't figure it out.
It should all mount there on that fender, rod and jack.
Here's the best pic I had lying around, I hope this helps. It is indeed a C-shaped-ish bracket that holds the jack and the rod, held down by a wing nut.
1981 Chevy C10 Custom Deluxe Stepside 350 V8, headers, side exhausts, 3-speed auto SOLD
1980 Chevy C10 Custum Deluxe Stepside 305 V8, Edelbrock Performer Intake, Edelbrock 1406 600CFM 4-barrel, TH350C. Bent rod. SOLD
1984 GMC Sierra Classic Longbed 6.2L Diesel SOLD
2009 Kawasaki KLX-250S too many mods for this signature
1999 Honda Accord EX 4-cylinder, 17" Motegi Wheels 215/45/17 Sumitomo tires, Tein S-Tech lowering springs, KYB GR2 shocks, Acura TL 20mm rear swaybar, debadged, blackhoused headlights, Short-Ram Intake
Cardomain of the Accord
cliffsta is offline   Reply With Quote
Old 11-26-2006, 02:54 PM   #3
Corellian Corvette
Thanks for the pic - my setup doesn't look like that however.
Mine has the brackets mounted to the inner fender. There is also some sort of brace that's riveted to the fenderwell.
Thanks though!
Anyone else?
Old 11-26-2006, 03:54 PM   #4
Ironclad454
Registered loser
Ironclad454's Avatar
I don't have a better picture, but you can somewhat see the jack set up in this engine pic from my 73. I'll try to get a better picture uploaded if you still need it.
-Nate-
There is no replacement for displacement
1996 Buick Riviera 3.8L S/C V6- DD
1973 Chevrolet Cheyenne Super C/10 LWB 454/TH350
Ironclad454 is offline   Reply With Quote
Old 11-26-2006, 05:37 PM   #5
Corellian Corvette
Yes that's looks like what I have. I'm still not sure how that long rod that folds in half fits exactly. If you could take a couple more it would be SUPER helpful but that's basically it...
Also - does anyone reproduce that "C" bracket for the jack? I don't have that...
Old 11-27-2006, 12:38 AM   #6
Ironclad454
Registered loser
I'll try to snap a few pictures tommorow. I havent seen any repro's so Im not sure if anyone makes them or not. Its probably going to be one of those items your going to have to find in a junkyard or on ebay.
-Nate-
Old 11-27-2006, 08:52 PM   #7
Ironclad454
Registered loser
Heres those better pics for you. Hope they help.
A close up of the Jack clamp.
-Nate-
Old 11-28-2006, 01:05 AM   #8
Corellian Corvette
PERFECT!! Thanks SO much!
Now, if anyone has one of those jack brackets I'll be in good shape!
