Old 11-26-2006, 09:01 AM   #1
braggwood
Where and what to buy??
I am looking to buy airbags for my 72 longbed (2wd) I want to go as low as possible with the bags, I have 3 inch front drop spindles and springs in the rear. Any sugestions on where to buy, size of bag and some part #'s would be very helpful. Thanks Greg
braggwood is offline   Reply With Quote
Old 11-26-2006, 10:43 AM   #2
67Fleet
Outlandish Trends - FL
67Fleet's Avatar
Re: Where and what to buy??
I'd buy from ***************** You can put your own kit together on their website and pick and choose exactly what you want/need for your particular setup. I'm running Slam Specialties RE7 bags front/rear, (8) 3/8" SMC valves, 3/8" line, (2) 3-gal tanks, (2) viair 380C compressors, and SD's front upper bag plates and lower cups cut down to 1/2". For fittings, I'd spend the extra dough and get the push-to-connect DOT fittings. They will make your life a lot easier and you will reduce your chance of leaks greatly, especially if you have no experience with air systems.
-Bret
67 short-fleet sold!
67Fleet is offline   Reply With Quote
Old 11-26-2006, 11:08 AM   #3
braggwood
Thanks for the info, I have looked at those, I want just the bags for now as I have a tank, lines, will make my own plates, cups and c-notch. the re6 re7, re8, is that the diameter of the bag? thanks, greg
Old 11-26-2006, 12:42 PM   #4
Grunion
Grunion's Avatar
yes
http://grunionfabrication.com/
Grunion is offline   Reply With Quote
Old 11-26-2006, 01:23 PM   #5
jimmydean
jimmydean's Avatar
I am running Slam Specialties RS72 front and RS62 rear. I would also say you are in good hands dealing with Suicide Doors. The guys there have been very helpful and the prices are great.
I went with all push connect fittings and they are great. I had to remount my valves and it the push connects made it way too easy.
jimmydean is offline   Reply With Quote
Old 11-26-2006, 03:18 PM   #6
72CSTC5
72CSTC5's Avatar
Dang you are asking on this site about bag recommendations? From the looks of your website and feature trucks it looks like you have it figured out!!
OOps I am an idiot. I thought Grunion aske the question on where to get airbag parts. Sorry!! You definitely have it down.
72CSTC5 is offline   Reply With Quote
Old 11-26-2006, 06:36 PM   #7
culookn
culookn's Avatar
it depends on how you want the truck to lay out. with a simple bolt on setup the truck will not lay frame. it will involve some extensive cutting an fab work. either way, suicidedoors is the way to go. if you give them a call theyll fill you in on the different options you have avail.
culookn is offline   Reply With Quote
Old 11-26-2006, 10:15 PM   #8
mkhutch
Throbbing Member
I have a new set of ART Coolride bags and shocks that you could use to do the front with. Make me a decent offer and its yours. I believe ART sells them for $549
mkhutch is offline   Reply With Quote
